Question about Panasonic NN-P794BF 1250 Watts Microwave Oven
My microwave runs for 30 seconds and stops
My microwave runs for about thirty seconds and stops the fan is running the hole time and it does have a humming noise but not continously and then shuts off.
  • Anonymous Mar 22, 2014
    Microwave runs 30 seconds and then stops. Power resets. Does not heat
    President:
  • 3,130 Answers
It could be shutting off because of the heat sensor on the magnatron is over heating because of a bad capacitor or diode or the power transformer its self. This is a call for the service man BUT you know these days a microwave like this cost a couple of hundred bucks maybe a little more too. But it will possibly cost 150 or so if not more to fix the average microwave. If you really like it, then see if you can have it estimated BUT its not for the handy man to try to trouble shoot as theres extremly high voltage in these puppys even when they are not plugged in!! Good luck
Posted on Jun 09, 2006
My whirlpool microwave does not work and flashes a F1E4,MW POWER RELAY. I assume this is a fault, but don't know where relay is?
microwaves ovens are not consumer fixable. They are too dangerous and have special security screws to stop you getting inside them. There are capacitors in there that have HUGE volts enough to throw you across the room or burn a hole in your skin, and a part of the magnetron has beryllium which is toxic, breathed, or ingested. Thirty seconds of microwave energy at 1 metre will blind you.
Take it to a Whirlpool dealer.
Oct 16, 2016 | Whirlpool Microwave Ovens
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
NN-T945SFX
The thermal fuse may be defective, monitors temperature of the magnetron, or the internal fan may not be operating properly, it is possible the magnetron may have a shorted winding.
Mar 22, 2012 | Panasonic Microwave Ovens
I cannot stop the DEMO
Demo Mode The Demo Mode is ideal for learning how to use the microwave oven. When set, functions can be entered without actually turning on the magnetron. The microwave oven light will come on, the fan will run, the countdown will run very quickly in the display, and the turntable will rotate. To Turn On/Off: The microwave oven and Timer must be off. Touch and hold TIMER SET/OFF for 5 seconds until 1 tone sounds. Repeat to turn off.
Jan 21, 2012 | Whirlpool Microwave Ovens
Microwave cuts off after 3 seconds. Magnatron?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 21, 2010 | GE XL1800 1100 Watts Microwave Oven
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Shuts off but everything else works
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
May 28, 2008 | Panasonic NN-S262SF Microwave Oven
Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Jan 09, 2008 | Microwave Ovens
Panasonic NN-P794BF 1250 Watts Microwave Oven Logo
274 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
