Question about Acer Aspire 3690-2196 Notebook
Acer eData Security
" Error deleting file or folder"
"Cannot delete file: Cannot read from the source file or disk" ,.
All that appears in a window when i turn on and while using laptop.
  • fee68 Mar 06, 2009
    my daughter downloaded lots of music from i think lime wire now i cannot delete it and keep getting something like cannot read from source file or disc. I am not the sharpest pencil in the box when it comes to all the technical jargon and what have you that comes with computers so a simple a solution that i can understand and follow would be very welcome. thanks.
Cannot read file that's blocked by password
it give massege : problem encountered on acer edata security managment operation
Posted on Nov 16, 2008
    Scholar:
  • 32 Answers
Most of the time this means there is a problem with the filesystem or possibly bad sectors on the hard drive. If you are running windows 2000, XP, or Vista, follow these steps:
Click on Start, go to Run, type in "cmd". In the command prompt, type "chkdsk C: /r /f"
That will tell chkdsk (Check Disk) to fix the filesystem and locate/repair any bad sectors. It won't be able to run while you are using the computer, so it will ask to run on the next startup. Be sure to say yes, then restart the computer and let chkdsk run.
As for why it happens on system startup is a little more bothersome. Unless you are trying to delete something, I would suggest getting and running Spybot Search & Destroy and if you don't have any antivirus, AVG Free (http://free.grisoft.com). Both are free and quite effective.
Posted on Oct 18, 2008
ON MY SLICK MP3 PLAYER ,WHEN PLUGGING IT INTO A DESKTOP , WHEN TRYING TO DELETE A CERTAIN FOLDER , A POP UP STATES .. ERROR DELETING FILE OR FOLDER , A BIG X THEN SAYS CANNOT DELETE FILE CANNOT READ FROM...
This sounds like you've got one of three things happening:
1 - Your USB cable is dying slowly. Over time connections become seperated within the cable. This causes data loss and all sorts of funny errors. Try a different cable and see if that helps.
2 - Your USB plug is malfunctioning or underpowered. If you are attempting to use a USB 2.0 device on a 1.1 connection, errors may prevent you from doing what you want to do. Try a different USB port, see if that helps.
3 - Your MP3 player has a setting somewhere locking files to the device itself. If windows tries to delete a locked file, you will receive an error. Browse through the manual of your device or the settings on the device itself and see if there's a lock or protection or USB mode somewhere.
Because you're getting the "cannot read from source or disk" error, I am strongly geared towards #1. Get yourself a new cable and see if that doesn't solve the problem.
May 04, 2011 | Audio Players & Recorders
Tip
All Problems have ONE solution and that is: www.longPathTool.com Path too long....
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 25, 2010 | Computers & Internet
Tip
How to delete files that are used by other programs in windows XP/Vista?
Today tip will help you to delete the files and folders that are being used by another programs and applications, for example a virus affected file. You have tried to delete such kind of files or folders and received the any following messages.
· Cannot delete file: the file is in use by the other program
· Cannot delete file: There has been a sharing violation
· Cannot delete file: The file is in use by another program or user
· Cannot delete file: Disk is not full or write-protected and that the file is not currently in use.
· Cannot delete file: The source or destination file may be in use
Normally, a windows restart will allow you to delete such files or folders that are being used by other program, but if you want to manage it without restart your computer then simply you need to download a freeware tool called Unlocker.
You can download this tool for any windows version using Unlocker link. Download it and run the easy setup.
After installation, right click on file or folder that you want to delete and select the option Unlocker.
If your requested file or folder is used or locked by other application then a small window listing of lockers will appear.
Here simply click on “Unlock All” button and now you can easily delete this file.
Thanks,
Bhautesh.
on Feb 23, 2010 | Computers & Internet
I had vista home prenium on my pc. I have famatted my HD and i can read the folders i have encrypted with acer edata security. what can i do?
Hello there!
How i managed to understand you have encrypted your folders with some encriptor , then deleted operative system , installed fresh copy and you cannot acess those folders anymore. There should be decryptor which works the same thing in opposite direction , search on their website maybe you will find it.
Also to advice you, next time make good profile of backup files, decrypt everything locked on old operative system, then setup new one and acess all files like normal.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Acer Aspire 5050-3242 Notebook
Acer aspire 4930
ok you deleted everything then it wont open any files if you meant to open something
Jul 23, 2009 | Acer Aspire 5050-3242 Notebook
Acer eData Security Management
delete/uninstall edata security completely.
Then download a more stable security like AVG, McAfee or Norton, check this site some are having the same problem and this seems to be the best solution.
Apr 09, 2009 | Acer Aspire 9300-5349 Notebook
Annoying files cannot be deleted...
First I recommend you try deleting the files from the Windows safe mode... it might work, or you an use the deleting software Unlocker
http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
Mar 20, 2009 | Microsoft Windows XP Professional
I want to delete the annoying files...
hello, where do you find this files? maybe its a permission issue.
first go on the map ->tools->folder options and view
and unmark "user simple file sharing" ->ok
then rightclick on the file and "properties" ->security tab
check the permissions. click edit ->add everyone and set full rights. try then delete the file.
Mar 10, 2009 | Microsoft Windows XP Professional
I have an Acer 5100. Freq. I have an error message. Reinstall
the eData security mangement is for security such as parental controls.u must have deleted it ,or possibly corrupeted the file you can find the neccesary downloads at acer pan am america,,steve
Feb 10, 2009 | Acer Aspire 5050-3242 Notebook
Everytime I open certain docs. I get told that "eDataSecurity was not properly installed! Please re-install the software" I then click Ok and the it says Windows explorer has stopped working.
It's becoming an anoyence considering I can't use my windows2007 anymore :(
Is there anything I can do to re-install eDataSecurity,so I can live out happy days with my computer and not decide to throw it out my window??
Jul 02, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 3690-2196 Notebook Logo
108 people viewed this question
Brian Sullivan
Brian Sullivan
