Panasonic DVD Recorder DMR-E55EB/EBL On turning this appliance on, the self check message appears and does not disappear, even after an hour or so. In the manual it says waiting until the message disappears, but it does not. Is there anyting that I can do myself. This appliance was working OK the last time it was used, several months ago. It is only 3 years old and has not been used very often
  • james700 Nov 22, 2008
    My panasonic DVD DMR-E55EB/EBL self checks for a very long time when switched on. It also starts about 15 minute late in pre recording mode. Can tou help me please?
    james@rankin598.orangehome.co.uk
I have a Panasonic TV model no MDR-E55EB/EBC WITH FREE VIEW BUILT IN HOW CAN I RECORD TO A DVD RECORDER I CAN RECORD THE ANALOGUE STATIONS OK BUT NOT FROM THE FREE VIEW PLEASE HELP ME THANK YOU
Posted on Sep 25, 2010
Panasonic dmr-e55eb-s
Hello Brian. Its not a Zener, it appears to be some type of polarised VDR or similar device. I have just literally one hour ago repaired an E55. I was about to replace the STRG6353 and had taken the old one out. I thought it a good idea to check a few components before going ahead.. I did a diode check across td3 and it showed short circuit in both directions. So I disconnected both ends and then it showed open in both directions.. Read a bit more on various forums and decided it was ok to fit the new STRG. I made a much larger heat sink for it. The machine immediately came back to lift.
If you want a bit of moral support e-mail me at johnatjbrewerdotfsnetdotcodotuk. Happy new year..
Dec 30, 2012 | Panasonic DMR-E55 DVD Recorder
Tip
DVD stuck on Panasonic DMR ES10 in eternal cycle of "self check"/"please wait"
My DMR ES10 was eternally in a "self check"/"please wait" cycle. Couldn't even turn it off normally. By pressing the "Power off" for 10 seconds it will turn off forcefully. Now, after it says "BYE" press the "CH UP" (on the recorder, NOT on the remote))+"STOP" (with the recorder turned off) for another 10 seconds. This will force the opening and we now can take the DVD off. Turn the DVD recorder ON and, if the problem is on the laser, because of dirt, etc it will work and we can now run a DVD cleaner. In this case, the machine was stuck just because the first thing it does is check the DVD inside, and because it can't and just keep trying, it will never do anything else, until we take the DVD off with it turned off.
on Oct 18, 2013 | Panasonic DMR-ES10 DVD Recorder
I need to know whether the Panasonic DVD recorder takes minus discs or plus discs DMR-E55EB/EBL
Hello there,
According to the manual, i believe that this particular model takes DVD-R discs.
I hope this helps! Thumbs up are much appreciated.
May 05, 2011 | Video Game Consoles & Games
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
My panasonic dvd model DMR-55 won't turn on and the digital clock is not even working when I plug it in. How do I get the dvd in the machine out?
My Panasonic is stuck on self check when a new DVD is inserted?
It turns on and other functions are in-accessible during this self check
Any help greatfully appreciated.
Feb 15, 2010 | Panasonic DMR-E55 DVD Recorder
DMR-E95H doing self check for up to an hour
Your problem may be Panasonic's common capacitor failures. Open case and look for capacitors with bowed out top and yellow substance. Replace both with higher rated capacitors from Radio Shack. Will need some soldering skills. Look on this site for "solder c1260 c1261"
Sep 01, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
A self-check for these models can sometimes last for 3-7min's (sometimes longer) depending on how much recorded data is on your hard drive. Plus it checks all unrecorded space on your hard drive as well. Don't forget that it must check 200Gig. If it self checks for longer than 20-30mins turn off at the wall and let cool down. Try again in an hour or so and it should rectify itself. If it continues to self-check for longer than 20-30mins refer your machine to an authorized technition
Nov 28, 2007 | Panasonic DMR-E80H DVD Recorder
Trouble with my Panasonic DVD recorder DMR-E55EB
Hi Dengle
The heat is caused by IC001 which is a regulator that is mounted on a completely inadequate heatsink on the power board. This component gets very hot during normal operation.
The regulator will usually last a couple of years, depending on how often the machine is used and then start playing up. The symptoms are intermittent operation, continuous self checking and rebooting, not being able to read discs and so on.
Eventually the component can short-circuit, burn out and take other components with it. The on-board fan is thermostatically controlled. It does not operate all the time, only when the unit gets hot enough. By using an external fan, you are keeping the unit cool enough for its own fan never to cut in. The additional cooling is probably squeezing a bit more life out of the regulator and is stopping its own fan from operating.
I have repaired lots of these and have never found a faulty fan, or fan switching fault. There's always a first time of course.
It is more likely that the regulator IC001 is faulty and if you are technically skilled, I would suggest you seriously consider replacing it. Use some heatsink compound and an extra heatsink, and it will probably do the trick. The regulator is an STRG6353. You can get these easily online from a number of outlets. Don't attempt a repair if you are unsure of what you are doing. Regards..
Nov 18, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
