Question about Yamaha RX-V361 Home Theater Receiver
Service Repair Manuel With Circuit Diagram
Dear Sir
The AV Recever works for 10 to 15 mins and then cuts off sometimes when we switch it on it refuses to come on and sometimes just comes on we need the circuit diagram to detect the fault. The model no. is RX-V361 and the Seriel no is T625717RT made in china
Please help us with this problem
Thanking you i remain your friend
Patrick Tomkyns
SOURCE: Circuit Diagram of Yamaha RX-V490 requied.
I have the schematics in PDF file, but how can I send it to you?
Posted on May 28, 2007
  • 236 Answers
SOURCE: Settings to work with CD Player
just want to know mam if you still need help for your receiver and CD to work
Posted on May 14, 2008
djproaudio
  • 515 Answers
SOURCE: Turntable connection
Yes, you'll need to purchase a PHONO PRE-AMP, and then connect the turntable to the pre-amp, and the pre-amp to the LINE INPUT of your receiver.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX-V361 cuts off: check SP cable
Disconnect the speakers and turn on. If your receiver is ok, it will not go into protection "check spkrs" Then connect speakers, one by one, each time make sure the receiver is off, then turn it on. When you find the speaker that's causing the problem it will go into protection. At this time, disconnect the speaker at the speaker, then turn on again, if it still goes into protection, you have a speaker wire problem. If it stays on, you have a problem with the speaker. If you have a multimeter and know how to read it, check the impedance and the resistance. Check the internal workings of the speaker, bad surround from dryrot or smoked crossovers, etc. look for the obvious first. Hope this helps
Posted on Jun 04, 2009
SOURCE: I have a yamaha receicer
Is the mute on?Reset the menu to factory default
Posted on Oct 26, 2009
I have a 2000 Monte Carlo SS, low beam headlights do not work. I have changed the headlight relay, headlight switch, checked all fuses, checked all bulbs, and cleaned the ground wires. What next?
As you can see from the diagram, the orange wire is voltage and fuse protected. The fuse circuit is hot all the time. Not only check the fuse, check the fuse circuit for voltage.
Dec 14, 2015 | 2000 Chevrolet Chevrolet Monte Carlo SS
98 grande marquis ls
You have a short in that circuit , you need a wiring diagram an a diagram that shows wiring harness routing an a volt - ohm meter to find the short ! Locating a shorted circuit can be a real problem sometimes even for a competent auto technician ! It would depend on what circuit it is ! You best bet would be to take to a ASE certified repair shop !
Jul 23, 2015 | Cars & Trucks
It is not cutting
Dear Sir:
Please see this possibilities:
Power from the house
test the blown fuse or c. breaker from your house
Door switch
test the switch for to starting relais and turn ON the main motor see the diagram
Wiring
test any wires for loose, burn, or break and repair
Timer or selector switch
test for defective, clean contact, repair any wires loose, burn, or break, see the diagrams
GOD BLESS YOU
5_13_2012_2_57_02_pm.gif5_13_2012_2_57_25_pm.gif5_13_2012_2_57_42_pm.gif5_13_2012_2_57_58_pm.gif5_13_2012_2_58_09_pm.gif
May 13, 2012 | Dishwashers
Behringer sx3242fx not working .i need circuit diagram .
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
Sep 09, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Bmw 525 sedan brake circuit light comes on sometimes when braking all brake lights working properly
1.see for the brake fuild level is ok if less then also the break circuit light might appear  2.if the brake switch fail on the fluid container then also the light appear 3.if the hand brake switch fail then also the light appear  4.if the hand brake switch have some play in ti then also in between suddently it will appear while brake is applied so for more solution do may check out or just visit your nearest authoried BMW service centre.. so untill then have happy motoring & safe driving so see you soon sir...!
May 24, 2009 | 1994 BMW 5 Series
My Samsung HT-40 home theater system throws itself into protection mode and shuts down. I put a new fan motor in but it insists on shutting down anywhere from 10 to 60 minutes of operation. No dust...
The fan is going bad and if you have replaced it try to open the case and remove the cover over all the capaciters and what not and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever! make sure u turn on the recever for 10 min if the fan is not turning by then its still not good
Dec 18, 2008 | Samsung Televison & Video
There is no video capture from video input
This happens sometimes when you use a Windows XP Driver under Windows XP Media Center Edition and vise-versa... They slightly different versions of Windows; Windows Media Center is preset to the default capture application and is very dependant on a DirectX Video Capture SDK.
What does this mean to you?
First, try getting a registry repair tool; I use Registry Booster 2 because it is a Microsoft Certified Partner. Moreover, it fixes driver errors in the system registry and "boosts" the system performance.
If you have McAfee Security Center or Norton System Works they also have a registry repair tool...
Uninstall all the software and drivers for the device...
Run the registry repair tool to remove all the invalid entries still hanging in the system...
After you restart your computer install the...
Lifeview FlyVideo 2000/3000 20.46 WHQL Driver
Nov 27, 2008 | LifeView FlyVideo 2000 / FM (701013821030)...
SONY AUDIO MODEL HST-49 RP SWITCH PROBLEM
I have bought one service manual for Rs. 700/-
Regards
claudeferns@rediffmail.com
Sep 14, 2008 | Audio Players & Recorders
Thomson and LG TV's difficult to switch on
It most certainly could be the cause of the problem. Most of the time when a TV set comes onm then switches off, its a fault in the power regulator circuit. Regulators can go bad all by them selfs, but most of the time, they fail due to excessive AC voltage, and or ppower surges, such as the oin off action of intermittant power would cause. On sets this old, Im not sure you would want to invest the type of cash to repair. Its onlty a guess but I would say a minimum of 125 to repair them? Its a call only you can make. You should go to this link and read this first. http://www.techlore.com/article/10602/ Good Luck Please do not forget to rate this link.
Nov 12, 2006 | Thomson 24WK25U 24" TV
Yamaha RX-V361 Home Theater Receiver Logo
572 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
