Question about OKI Electric Industry C3520 Laser Printer
Toner sensor error
Please can you help me solve a toner sensor error on my oki c3520 thanks.
  • info980 Oct 18, 2008
    Thank you. this is sort of right. I have fixed it now. I used a cotton bud to clean the sensors - they are on the right hand side og the drum / cartridge a little black square both on the cartridge and the right hand wall of the printer itself, & now it is ok. What a palava. Thank you for you help.
  • cosmati Nov 22, 2008
    My C3520 is just over a year old. I installed a new magenta toner cartridge last week (genuine expensive OKI toner) and have use the printer intermittently since then. Today I was printing an 23 page document but experienced a paper jam three quarters way through. I resolved this but am now getting a Toner Sensor Error on the magenta cartridge that I cannot resolve. I cannot see where the little windows mentioned above are on the cartridge or on the wall of the printer that I should attempt to clean. Any tips gratefully received.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
The toner cartridge has a small window from outside where the dark blue handle. You should turn a photodrum gear wheel while the window will not open. After that insert a drum unit and work.
If you have "start cartridge" that doesnt work....
Posted on Oct 18, 2008
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Mar 16, 2010 | OKI C3400n Laser Printer
PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
My Oki C3200 has the following error message 541:m Toner Sensor Error
There are several reasons for this message... we will start with the easiest to solve. Here is a link:
http://www.katun.com/downloads/oki-c5100tnrcartiis.pdf
Jun 03, 2009 | OKI C3200n Led Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
Resolution:
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
Toner sensor error
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Feb 11, 2008 | OKI C5200n Laser Printer
Problems with Oki Printer and Toner Sensing
Yup Dodgy refill cart without require chip to identify itself to the printer or cart not suited to b4200/4250 , get a real oki toner from your country that suits exact model.
here is code for required product
OKTCOB4200
Oct 31, 2007 | OKI B4250n Laser Printer
OKI Electric Industry C3520 Laser Printer Logo
813 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
