Question about OKI Electric Industry C3520 Laser Printer
Toner sensor error on an Oki C3520 Laser
Please can someone help me with my Oki. I have just replaced the balck & yellow toners (They were empty) and now the screen says 'check toner cartridge yellow / black toner sensor error.
I need to print desperately over the weekend and there is no help line avaliable from oki. Please tell me what to do!! Thanks.
  • 1 more comment
  • Anonymous Mar 13, 2014
    Oki Electric Industry 449 oki error
  • Anonymous Mar 31, 2014
    OKI printing solution printer kept asking to replace the toner
    error
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
toner sensor error on an Oki C3520 Laser - 0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
toner sensor error on an Oki C3520 Laser - moz-screenshot-2.jpgsrc="http://i.fixya.net/uploads/images/moz-screenshot-2.jpg" alt="moz-screenshot-2.jpg" class="h_mi" />
Posted on Dec 07, 2008
OKI C6100 Printer Error Messages: K Toner Empty Y Drum Life
Needs Black Toner and Yellow Drum
Replace both while printer is on
Feb 10, 2011 | OKI C6100n Laser Printer
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
0.106?openelement&fieldelemformat=gif
Mar 16, 2010 | OKI C3400n Laser Printer
I have just put new toner cartridges in my Oki C3400 and I am getting the message of "toner sensor error"
look this solution http://my.okidata.com/oki-faq.nsf/FAQCentral/C384D8F74A91CF6E8525765E0065F636?OpenDocument
here the solution for your problem
i hope that it's helpful .... bye
Mar 05, 2010 | OKI C3400n Laser Printer
My laser printer used to click when starting up on the yellow toner now yellow does not print at all.
Replace Y toner cartridge (use oki ones or risk it not working for you, but I have warned you now) it was low (sensor clicking) now it is empty(stop operations)
Chances are that you will then need the other colours too, they all go about same time, but depends on what colours you print, normally black goes first then 3 colours, lights and software should indicate but once it is empty totally all will stop...
You can check visually by removing suspect drum and toner, putting on desk, remove toner cart. from top of drum, inside drum running the width of top surface is a 2 x 15cm wide slot, it needs to have the toner to the brim of this slot (foam edged), there also needs to be toner left in the toner unit itself thats sits on top of this slot.
Cheers
Nov 02, 2009 | OKI C5200n Laser Printer
Toner warning
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Feb 03, 2009 | OKI C5200n Laser Printer
Printing in grayscale
yes u can use it with black and white
Nov 01, 2008 | Dell 3010cn Laser Printer
Toner sensor error
The toner cartridge has a small window from outside where the dark blue handle. You should turn a photodrum gear wheel while the window will not open. After that insert a drum unit and work.
If you have "start cartridge" that doesnt work....
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Mar 28, 2008 | OKI C5200n Laser Printer
OKI Electric Industry C3520 Laser Printer Logo
2,826 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
