Question about APC (SUA3000I) UPS System
No power hi wetn to turn pc on ..but no power no lights nothing. checked plugs and leads but no power getting to pc...help
  • 728 Answers
You might need to change sockets. If that doesn't work, you might need a new power cord. If when you get a new power cord and it still doesn't work, then there is something wrong with computer internally and it needs to be taken to a shop.
Posted on Oct 22, 2008
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
Wont turn on at all
Apart from the obvious (check the fuse in power lead) it sounds very much like a mainboard issue...It may be advisable to take to a local tech who will check it for you.
Feb 10, 2014 | HP Dandelion Breeze Laptop
Hi! Having some trouble with a friends laptop here. I have it on AC power and the battery is now charged (middle light has changed from amber to blue). So when I push the power button, the top light...
Hi.
Try unplugging AC power lead and then take out the laptops battery, plug the AC power lead back in and try turning it on, see what happens. If the laptop turns on then there is a problem with the battery.
Good luck and let me know how you get on.
Regards.
Jan 29, 2013 | Computers & Internet
I had problem with my HP laptop as i start power it gives light signal but nothing get display on the screen. i try to fix problem but i could not do it as nothing display by screen and don't know which...
remove battery and power plug hold power in for 50 seconds the leave battery out hook backup power lead and try turn on. My tech team and I can help lots with PC stuff it would begreat if you could ask any PC questions you have here so we can discuss itproperly http://www.mypcmates.com
Nov 11, 2010 | Computers & Internet
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Battery Wont Charge on my Acer Aspire One Notebook Orange light flashes when power on button is pressed I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Try this:
Drain the static on the computer by removing the battery and the power adapter. then press the power button for 1 minute and release. Then plugged the battery back in and turned on the computer, if the computer won't come on plugged the Adapter back to the computer and try turning it on.
If problem persist it is possible that the battery already busted and you need a replacement.
Hope it would help.
May 10, 2010 | Acer Aspire One PC Notebook
Emachine T3958 wont turn on
make shure that the 4 wire plug to ther mother board from power supply is plugged in..other wise try a new power supply
Oct 09, 2009 | E-Machines eMachines Desktop PC
Laptop wont turn on this a weird one!!! Please help!
Its very unfortunate but you've short circuit your power supply and before it get worse, please check it out with your vendor asap. It might cause severe problems.
I'll not suggest you to get your hands on to resolve this.
Hope this helps and you get your laptop up.
Thanks.
Mar 06, 2009 | Computers & Internet
Acer aspire e500 won't turn on
Check that all the power supply units are switched on( Wall Plug, UPS, CPU), If all is ok and the problem exists, replace the CMOS battery.( if the sys works replace your CMOS Battery, configure the cmos settings also)
Jan 03, 2008 | E-Machines T1360 PC Desktop
APC (SUA3000I) UPS System Logo
78 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
