Question about Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1200 drum not turning
Everything else making the right noises, motor going into spin cycle, filling up, pumping out, heating water etc.
  • 22 Answers
Is the belt ok?
Posted on Nov 13, 2008
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
My zanussi aquacycle 1100 is making a very heavy clonking noise on spin cycle.Have you any suggestions? Thanks Craig
Sounds like the main drum bearings have gone.
Turn the drum by hand and if it feels rough or noisy , the bearings have gone.
There should be little or no noise when you turn the drum by hand.
It is quite an involved repair , as it entails a complete strip down.
Plz rate my comments.
Tanks, and merry xmas.
Dec 20, 2008 | Washing Machines
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Jul 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
705 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
