Question about Toys
Peg perego polaris 4 wheeler
The battery shows that it is charged, but the vehicle won't move at regular speed.  No grinding as if gears are shot.
  • 4 Answers
If it runs only in slow speed your hi/lo speed switch is bad. Cheapest I've found is at tigerimports.com part#MEPU002 for $11.00 plus $2.00 shipping USP. Hope that helps.
Posted on Oct 19, 2008
Peg perego polaris 700 4-wheeler wont run
Had the same problem. Once a year open (if possible) gas throttle and gear shift. Use a standard lubricating spray on everything. (power off first) shake and use compressed air to spread. Potmeters are dryed up and dont get signal. Let it dry after you sprayed it some times. Make shure you move parts. Connect and should be ok.
Apr 02, 2014 | Polaris 800 Twin Sportsman Ride on Toy
Peg perego 4 wheeler
is it a 12v or 6v four wheeler?
Jun 27, 2013 | Toys
Tire makes a grinding noise on perego polaris sportsman 800
Why dont u try adding grease to the nuts and screws then loosen the nuts a bit to give air space...try it out
Dec 28, 2011 | Polaris 800 Twin Sportsman Ride on Toy
Where can i find spare part sag18972xwtn for polaris ranger rzr in the uk.Its the gear by back wheel
Get in touch with Wacky Wheelers - at http://www.wackywheelers.com/shop and they should be able to help you
Sep 20, 2011 | Polaris Ranger RZR Ride on Toy
My son had peg perego 4 wheeler electric and I had extra battery He only 1 cricle around the house and it stop even battery been charge please help
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Aug 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Our polaris 4 wheeler will not go forward only reverse. How do we fix this problem?
rmove the battery and black plastic piece under the seat, this will give you access to the shifter switch, make sure that both of the connectors are connected
Jul 04, 2010 | Polaris 800 Twin Sportsman Ride on Toy
Peg perego 800 Polaris 24v will not go into high gear..reverse and low gear fine, but will not kick into high gear..what to check for??
did you remove the high speed lockout? if so then you probably need a new foot pedal, let me know if you do i can order you one
Jun 04, 2010 | Polaris 800 Twin Sportsman Ride on Toy
My son's Peg Perego only runs in reverse. Any suggestions?
41 • GEAR SHIFT LEVER: The vehicle has three
speeds. ATTENTION: When the vehicle is first
removed from the packing, it only runs in first
gear (1) and reverse (R). To use the second gear
(2), proceed as follows:
42 • Screw down the second gear unit, as shown in
the following figure.
43 • 1-R: The second gear unit protrudes from the
chassis, preventing the gearshift lever from
moving down to the second gear. 1-2-R: The
second gear unit is completely screwed into
the chassis, and the gearshift lever can be
lowered.
link
http://www.pegperego.com/pegcatalogue/toys/downloads/Polaris700TWIN_FI000801G121.pdf
Look at diagram on page 4 of 44
Apr 28, 2010 | Polaris 800 Twin Sportsman Ride on Toy
I have a peg-perego polaris four wheeler. One
I would take off the wheel that is not spinning and see if the wires have come loose.
My grandson had a polaris 700 and one of the wires had come off.
I needed a gearbox 3 days later (go figure) and I got it at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-batteries.html
These guys help me out with all my toy problems.
Hope this helps
Jul 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
726 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
