Question about Mitsubishi LT-3020 30 in. HD-Ready LCD Television
Thank you vcdr for your solution. I did what you suggested and the problem presented itself. Could this be simply a poor connection of the cable into the jack or do you still think it is a cold solder? It actually appears to be a cable into the audio jack on Component 2.
  • 53 Answers
You could try a new cable.
Posted on Jun 08, 2006
Wd60737 audio present but picture black
follow this recomendation and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a Mitsubishi projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Mitsubishi Televison & Video
60 inch mitsubishi comes on no picture only sound and then it will turn off by its self
Most mornons seem to think that your TV is a traditional crt projection when in fact it is a DLP projection set and does not have convergence chips or CRTs. Instead, your set has a DMD chip and a projector lamp that passes light through the light engine where a color wheel is and the DMD chip itself. Often times DLP TVs cycle on and off again when the lamp is starting to go out. Mitsubishi is well known for this. However, it can also be a symptom of the color wheel going bad as well or simply updating the software by downloading it from
Good luck and rate me when you can.
Nov 30, 2011 | Mitsubishi WD-60737 60 in. HDTV
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The whole projection is yellow in colour and we need someone to have a look at it. Can you suggest anyone in the Brisbane metro area?
I can possibly save you from having to call someone in.
2 things that you should check before you have someone called in to look at your projector.
1. Color correct in the system menus, you can individually adjust the color levels in this menu. Increasing and decreasing the values can help relieve the yellowness presented.
2. If at all possible, buy a replacement bulb for your projector and if it doesn't work, simply return it.
May 31, 2011 | NEC VT670 Multimedia Projector
My tv will turn on there is no picture and it
The only two parts that can cause scratching sound are the color wheel (if present) and the cooling fans.
The TV must be taken apart and tested by a technician.
To get in touch with a qualified technician ring the number listed on the user manual or check your Mitsubishi support website.
May 11, 2010 | Mitsubishi WD-65733 65" HDTV
Where can i buy a color wheel for a mitsubishi wd-73831
The color wheel from Mitsubishi PN# 938P030010 is the part that you are looking for.
But I could not find anyone on the internet that can sell you one.
You may try calling Mits, but they are going to suggest that you call a local servicer to diagnose your set and you are looking at 350-400.
Sorry I could not be of more help.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
Mar 12, 2010 | Mitsubishi WD-73831 73" HDTV
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mom's tv
sounds more like a solder issue.actually leaving the unit plugged in may actually help a solder problem as the standby voltage is present and sometimes solder tends to fix itself with voltages present.
Feb 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65819 got Fried by a mouse
Just replacing the board if its the main board is half of the repair. The memory IC which is usually located on the main board holds all the data for convergence,picture geometry,channel memory,color settings etc..So getting it to run is only half of the battle. Got to and look for the main board. I couldn't however look it up because it says your model number is invalid.
Mar 14, 2007 | Mitsubishi WS-65819 TV
Mitsubishi LT-3020 30 in. HD-Ready LCD Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
