SOURCE: error messege
Check paper out switch behind tractor assembly. It may be bent and also make sure that the green bar (if used) is installed carrectly between the tractors.
SOURCE: error messege in printer tally
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: My Tally T6218 gives the
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
SOURCE: How do I clear a "config 1" error on my tally t6218 printer
Click start>run>type services.msc. The services window will come up and you can right-click on the Print Spooler and then click Restart. This will clear the print queue and hopefully allow you to print. Good Luck. Let me know if you have any questions.
