Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
Laptop Charging Help!!
I have a Compaq Presario 2100 the plug in on the back to where you plug in the cord to charge the battery has come out so I cant charge my batter nor can i use my laptop. I was wondering if I bouhgt a USB cable and a USB station that I could plug into the outlet would allow me to use my laptop again, or would I just have to go get the plug in fixed?
  • 45 Answers
You should get your laptop plug fixed for sure.
Patrick
Posted on Nov 12, 2008
My compaq presario c795tu battery is not charging
Unplug the power supply, take a stiff tooth brush and clean the battery terminals in the laptop plus the battery, re-install the battery and plug the charger in, If that fails you need to find out if the charging circuits are putting out the proper voltage before you replace the battery.
Mar 04, 2012 | HP Compaq Presario CQ40-330TU
Battery charger
Yes. Usually they either work or they don't so obviously when they test good they should charge the battery. Dell laptops have a "data pin" that determines what wattage of power cord is plugged. If this data pin goes bad on the power cord or motherboard the laptop won't charge.
May 03, 2010 | Compaq Presario Notebook
Help! Compaq Laptop "Plugged in,Battery Not Charging"
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Sep 11, 2009 | Compaq Presario CQ60-220US PC Laptop
My Compaq Presario 2100 laptop won't boot up
Try removing the battery, then put it back. Plug the charger and charge it first, then start over.
Aug 13, 2009 | Computers & Internet
Compaq presario C501nr wont charge battery
its in your power jack its a common problem try to check and change.
May 06, 2009 | Microsoft Compaq Presario C501nr Notebook
Compaq presario v6000 laptop plugged in but not chargin
YOU NEED TO RECALIBRATE YOUR BATTERY. FIRST UNPLUG THE POWER CORD AND LET YOUR BATTERY RUN ALL THE WAY DOWN TO 5%. THEN PLUG YOUR POWER CORD BACK UP AND LET IT RE-CHARGE THE COMPUTER. SOMETIMES WHEN YOU FREQUENTLY UNPLUG YOUR AC ADAPTER YOUR BATTERY FORGETS HOW MUCH POWER IS ACTUALLY AVAILABLE IN CONJUNCTION TO WHAT THE BATTERY METER IS SHOWING. RECALIBRATING THE BATTERY WILL RE-SET THE METER WITH THE BATTERY.
Apr 06, 2009 | Compaq Presario Notebook
Laptop shut off without warning
try removing the battery without the ac adapter plugged in then plug it in and turn it on hope that helps.
Jan 15, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Power supply malfunction?
Remove the battery and try the cord again. Complete with the moving it around. It sounds like you have already diagnosed the loose DC plug adaptor, but the battery could have gone terminal.
Apr 17, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
