Question about AudioBahn A12001DQ Car Audio Amplifier
Audiobahn A12001DQ amp need assitance and/or guidance on repairing...
My am has blown capacitors in it from water dmg and i need to no where to get these caps and any other parts needed to repair it... the only noticable dmg is the caps but everything else volts ohms power and all read what i think is correct out of it.... so please need assitance some kind of direction on where or what i need to do about it... Thank-you... my email is j.mitchell.adams@gmail.com so if any information on this amp or where or what i need to do or go please contact me vie this website or my email... Thank-You
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
I just seen one on ebay today
Posted on May 11, 2010
What does it mean when my green lights on top go up to red
it is in protect mode. check the ground first and make sure it n bare metal on the frame. then check the ohm load s the subs make sure its safe for the amp. then try backing the gains down a little bit, electronics dont do well when they get hot
Sep 15, 2010 | AudioBahn A12001DQ Car Audio Amplifier
Amp not working
I had a similar problem with a pyle amp. try to disconnect the speakers and turn it on if the protect light doesn't come on then you might have blown something in your amp and it needs to be repaired. For my situation it was a blown resistors and only 1 channel worked. If you don't have soldering experience then I wouldn't bother trying to fix yourself, an unsteady hand can ruin your repair.
Mar 26, 2010 | AudioBahn A8000T Car Audio Amplifier
I believe it got some water dmg from water dripping from the ceiling. Can it be repaired? It makes a clicking sound when you turn it on, but it shows no picture.
That might be the ballast trying to ignite the lamp. You may have some serious problems. Have you tried replacing the lamp yet to make sure that ballast is good? If not, then you need to check the lamp then the ballast.
And also the power supply may be bad. You can open it up and take a look to see if the power supply has any blown capacitors too. A blown capacitor will look like an upside-down battery mounted to the board, but with a bulge out the top.
Feb 04, 2010 | RCA D52W19 52" Rear Projection Television
Audiobahn a4002t beats steady and alternates between power and protect mode. need help.
That usually happens when your amp keeps clipping and basically doesn't have enough juice to push the speakers. You can try to ground the amp better, preferably to the chassis, and you can also get a capacitor and see if that helps keep the steady power going to it. There are those times that the amp is just getting old, but I would try these simple solutions first. Hope this helps.
Dec 31, 2009 | AudioBahn A4002T Car Audio Amplifier
Accidently ran a 2 ohm speaker and amp stop working
you must send to repair,some components inside will be burned due to excess power.
Aug 12, 2009 | AudioBahn A12001DQ Car Audio Amplifier
Audiobahn A6601T amp. Protection light on. No Sound output.
Disconnect all speakers from the unit and then switch it on. If the protection light is still on then the output stage in the amplifier is blown.
May 12, 2009 | AudioBahn A6601T Car Audio Amplifier
I have an audiobahn a2300hct with blown components.
IRFZ48ZPBF-ND
^ from Digikey.com are a good replacement. You need to replace all of the Z48s on the side of the amp where the ones that failed were located. Digikey will also have the resistors. There may be other problems. If you're new to repair work, read through the following page.
Basic Amplifier Repair
Let me know if you have any other questions.
Dec 10, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
AUDIOBAHN a2300hct problems
This indicates a possibility of a power supply issue, you may have to open up the unit and take voltage measurements to determine if the voltages are correct. In order to do this you will need a schematic diagram of the unit. Once you have the schematic you will be abor to tell which voltages are legitimate. I hope this helps
Sep 15, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A1500HCT in Protection Mode
try just hooking up a power wire and ground wire only. disconnect your subs from your amp along with the remote wire and RCA's. if you have some jumper wires or run a wire from the power terminal to the remote wire. YOUR amp should come on, if it still stay's in protection mode it might be shot... hope this was helpful, i couldn get my a2300hcx to come on and tryed this and it came on turns out it was my remote wire was bad of the head unit...
Nov 13, 2006 | AudioBahn A1500HCT Car Audio Amplifier
AudioBahn A12001DQ Car Audio Amplifier Logo
105 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
