I CANT GET MY LAPTOP TO WORK WITHOUT THE ETHERNET CABLE IN?
    Novelist:
    Scholar:
  • 84 Answers
When was the last time using your internet connection wirelessly? If this is the first time you will use your wireless internet. You may need to check it with your internet service provider or you may check it with your wireless modem (router) manufacturer.
Using wireless internet connection, you will need to configure the settings in the wireless modem (router). you will need to get an admin password and username.
If you were able to connect to the internet wirelessly, check if you wireless icon (WIFI) on your laptop is on.
Keep me posted.
Thanks.
Posted on Oct 18, 2008
Trying to connect to internet cant find wireless & cant find a ethernet place either
The laptop in question does not have a place to plug in the ethernet cable. The laptop is not fitted with wi-fi or bluetooth adapters either. The best and cheapest way to connect this laptop to the internet is using a PCMCIA Card Adapter (type two or three as both are supported.) such as the product supplied by linksys. If yours is similar to the one in the photo then it should include a cable with the required network connection on the end. The "linksys" card you mentioned is no doubt the correct one, but minus the vital cable!
May 20, 2016 | NEC Versa LX Notebook
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
Xbox and laptop cant connect at the same time
your ethernet cable from comcast gets plugged into the wan port of the linksys switch. plug the xbox and laptop to one of the lan ports. the comcast box is a modem/router? without the router it won't assign dhcp addresses
Aug 19, 2017 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Wireless switch on my pc is on but cant connect Work with ethernet cable plugged in.Are there any settings?
Things to try:
1. Plug in the ethernet cable then restart the laptop.
2. Right click on your local area connection and make sure its enabled
3. Make sure your wireless adapter is disabled.
4. Check if you need a static ip address on your work network. and if so have them assign you an ip address for your laptop.
5 Test your computers ethernet port on another wired network to make sure that it is good.
6. Get a usb to ethernet adapter for your laptop if your ethernet port is bad on your laptop.
Sep 11, 2009 | Intel Computers & Internet
Xbox live - no connection
hey im having almost same problem, i got a motorola s8vs SURFboard cable modem with a battery in it and my ethernet ccord runs from my modem to my xbox but yet my xbox cant read my ip adress, why is this.. do you know?
Dec 28, 2008 | Microsoft Xbox 360 Elite Console
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Plugged ethernet cable innto laptop from cable modem and nothing
Click Start / Control Panel / Network Connections.
Your Ethernet status should show under LAN or High Speed Internet. It might be disabled, in which case, right click & ENABLE.
Let me know how you get on.
Jan 10, 2008 | Dell Latitude C640 Notebook
Trying to get router to work
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
