Question about HP PSC 1410 All-In-One InkJet Printer
No power once the power is switched on all the lights on the panel come on and nothing else can be done
  • 39 Answers
If your manual does not give any instructions for clearing up this particular problem, more than likely you will need to have the printer repaired by a professional. If it is still under warranty, contact the manufacturer about a replacement. If it is not under warranty, you might try to contact the manfacturer anyway. Sometimes (not often - but sometimes) they can/will give you some insight into the problem. - Graye
Posted on Nov 24, 2008
Once power on the monitor after 20 seconds power off how iam rectifed
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 30, 2014 | Samsung SyncMaster 920NW Monitor
Bobcat 896.. I don't have any control lights come. On when I turn the key switch on. Checked all relays and fuses, getting power to them but no panel lights to even try to start
Check your ignition switch. There is an electrical component that turns on some electrical stuff when you turn the key to accessory. I had a similar problem once. Do not confuse the key locking mechanism with the switch.
Mar 29, 2014 | Toys
Samsung ln46b530 keeps switching between inputs on it's own
I had the same problem. It has nothing to do with power supply board. Its the switch assembly board on the side of the set. Once I disconnected the board everything was fine including the remote fuctions.
Oct 14, 2012 | Samsung LN46B530 LCD TV
Calling for heat red light flashing 2times
Hi, pull the panel off the unit where the light is flashing. If everything stops working, then you have a switch around the perimeter of the panel that killed the power and you will need to tape it down to restore power to the furnace. Once this is done, ( if it even happened ) look on the panel or the unit for a strip of paper that will be glued there telling you what each code means, and what to do to solve the problem. 2, 3, 4567 flashes mean different things going on. It may have tripped a limit switch, flame roll out switch ect. These are manual reset switches, so you will have no problem resetting them. I hope this was of help to you.
Shastalaker7
A/C, & Heating Contractor
Sep 19, 2011 | Intertherm Heating & Cooling
Hit power button and nothing other than lights flicker once
Remove everything from the board except the front panel hookups.Make sure you remove memory, video card, hard drive and cdrom cables, hard drive and cdrom power, anything plugged into the back except the power. If it will power up this way start plugging things back in between power cycles. Start with memory then power down. Then add video then power down. Continue with Cdrom, then hard drives. When it stopps wanting to power on you know where the issue lies. If it wont power on with nothing on it then the motherboard is probably bad. Hope this helps.
Aug 08, 2009 | Intel Motherboard
Power drivers side mirror
Yes you have to pull of the door panel. Nothing complicated once that is done. The wiring plug should be visible after you get the door panel off. Unplug it, and remove the bolts holding the mirror on. Reverse to put the new one on.
Jun 17, 2008 | 1999 Pontiac Grand Am GT
Error Message CL in the front panel
Error message CL solved. CL means child lock. To deactivate press two linked buttons (on my machine the right options button and the temp button) together for a couple of seconds.
Mar 29, 2008 | LG WM-12230FB Front Load Washer
HP PSC 1410 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
