Question about Intel Computers & Internet
Audio driver i reformat my pc because someone made a password but they forgot it i success in reformating but then my speaker & headset did not function because i have no audio driver for it my pc mother board model is d34223-001 n sy24d-p1 fo9a-12b3s1 d2ac112 dc12v 0.42a please help me tenks
Hola tengo problemas para instalar lo drivers de audio
Posted on Oct 18, 2008
No audio on VGN-FE780G, symbols indicate everything is fine
right klik on system tray bottom right on ur screen on the speaker icon ,
left klik on playback devices
make ur speaker icon the default player,
done,
Mar 29, 2017 | Sony VAIO VGN-FE780G Notebook
Laptop battery died; even after replacing, ever since, audio is not working.
Hi ,
It can't be a driver issue since you can get audio with your headset . So , we are left with dead speakers who need to be replaced or completed by an external set .
Regards .
Mar 03, 2013 | HP Pavilion dv7-6c90us 17.3" Entertainment...
There were no audio device install during the reformation of using other windows of this laptop (acer) aspire 1 d255e-13ckk
Good Day Albert!
After reformat and installation of Windows, you will need the drivers for your audio.
Download audio driver here, go to:
http://www.netbookfiles.com/12880/acer-aspire-one-d255e-audio-driver-win7-32bit-6016246/
and
To look for other drivers that you will need for your Aspire One, go to:
http://www.netbookfiles.com/netbook/Acer/Aspire-One-D255E/1
Jun 09, 2011 | Computers & Internet
My desktop speakers not working but cable all plugged in and audio device working.
Hi tamjidzaee ,
Please follow the below steps to solve the problem that you have mentioned :-
  1. Check if the sound driver has been installed in your system, you can check this by going in the control panel's sound and audio devices option , if you find all options disabled and it reads no playback devices and no recording devices, then you have no sound driver installed. Therefore in this case you would require to install your sound driver using your motherboard cd.
  2. If you see your sound driver is installed in the audio options of the control panel and you also see the sound driver's name , then you need to check the volume in the volume settings to check if it has not been muted accidentally , if it has been muted , then please un mute it and things should work fine.
  3. A good idea would be use a headset and plug it into your motherboard in the slot where the speakers output is received , mostly the green round slot.
  4. If you have a front head phone option then you can try using it as well, if the headphone or headset works fine, then we are sure about two , things that the driver is installed successfully and there is a sound output from the audio output slots.
  5. Now, when you have checked the sound via headsets then you need to make sure that you are connecting your speakers in the green slot or the same slot which is working for headsets, remember headsets can be used to check the output in the back panel of your cabinet as well as front panel of your cabinet.
  6. Also check if there is any fuse in your speaker which has blown up so that you can replace it and it would start working, check the power cables and confirm they are not properly connected.
If the speakers work fine , then it's all ok , but if they don't you need to replace the speakers by checking them with your friend's pc or any other audio output device.
Hope his helps.
May 11, 2011 | Computers & Internet
No sound at all
you may have a broken speakers, replace it. might as well check the sound card if its tripping replace it.
Jul 15, 2009 | Computers & Internet
Were can i install drivers for my speaker. i have just reformated and the speakers don't work
Speakers don't have drivers.
You need drivers for the audio/sound adapter in your computer that the speakers plug into.
If the speakers plug into an add-on card, open the case and note the make and model of the card. Go to the manufacturer's website, download and install the audio driver.
If the speakers plug into the motherboard (e.g. the plug is situated near the computer's USB, keyboard and mouse plugs) then you need to look up the system or motherboard at the manufacturer's website and get the driver from them.
I hope this helps.
Jul 12, 2009 | HP JBL Platinum Computer Speakers
No audio after reformating
If there are no problems in device manager like a yellow question mark or exclamation mark on the devices, that means the other drivers are installed properly. Try to check if the speakers are ok as well. Try the speakers on another pc or device and check if it's working there just to eliminate the speakers as one of the problems.
Do you have an integrated audio?
Apr 30, 2008 | HP Compaq Presario SR1430NX (PS566AA) PC...
Computers & Internet Logo
140 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
