Question about D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch
D-Link DES 1005D
I have 2 pc's i want to go online with but only one of them can gain access.
i am using standerd ethernet cable.
all the pics i have seen on this site about theD-Link DES 1005D it looks different to mine mine dosent have a stand alone soccet for the broad band cable it just has 5 in a row the pc that is connected at the moment is runnin vista but the pc that cant get on is runnin xp it gives me a ip addy but its the same as the gateway address and i dont get a dns
  • Anonymous Mar 01, 2009
    i have 2 pc s how i can connect one master
  • 3 Answers
Set u r borad band router/modem to dhcp and set both system to auto detect ip address put u r boradband ethernet cable to hub and both pc in same hub that it nothing to do with configure  enjoy!!! need help for router/mode to configure tell me the model number i will tell step by step
Posted on Oct 18, 2008
How to connect des-1005d
The new model. Just plug it in. No configurations. Any port for any use. The selling point is unmanaged. Look for the problem somewhere else (including the cables) till you are sure it's the switch. Then it needs to be replace.
http://files.dlink.com.au/Products/DES-1005D/Datasheet/DES-1005D_N1_Datasheet_11.pdf
The older model uses standard cabling practices, but still very versatile.
http://www.dlink.com/uk/en/support/product/-/media/Consumer_Products/DES/DES%201005D/Manual/DES%201005D_Manual_v02_EN_UK.pdf
Oct 25, 2012 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Tip
Trying to connect 3 pc to a dlink switch
I have an internet connection at home which 512 Mbps. I have bought Dlink Switch DES-1005d. I have 3 pc at home. I want to share the internet connection among the three pc. I have tried just by connecting the pc with CAT5 cables. I just have the received packet and then I do not have internet connection at all. Please can someone help me?
Thanks in advance for your help.
Best Regards
Jerman
on Mar 28, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
My home network is such that I have a DLink Gigabit switch right behind my DSL router to dispatch network connections through the home. I already connected several devices that work without problem. One...
Check the network settings of your pc in network and sharing, adapter settings , right click local area connection and press properties, click IPv4 and look at its properties. Ensure ip and DNS are bother set to auto.
press start, type cmd right click the grey chalk board press run as administrator. Type ipconfig /release then type ipconfig /renew
also try a different port/cable if it is a gigabit switch an orange light means it is running below the speed. I.e. 10/100 if it is working correctly the lights should be green.
Apr 06, 2017 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I am trying to install the d-link ethernet switch to my virgin modem 256. I can succesfully get either my PC or my laptop connected to the internet but NOT both at the same time. Any ideas how to solve...
You need two cables one from the Modem into the internet port on the back of the router and another from Computer Port 1 into your computer then you should be able to connect via wireless. If not get onto the router CP and check the settings.
Jan 06, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have an Apple Mac connected to Netgear router. Partner has Del laptop which she wants connected via my router. Bought D Link 1005D switch but don't know how to connect both of us thru it. Do I need set...
What type of Netgear Router you are using?
If you have more than one ethernet ports to your Netgear Router, then connect your switch with a patch cable to the Router. Switch on it and check.
So that can share the resourses.
Dec 28, 2009 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Rating specification of hub
i am giving you some page link where rating is being done on this product
1.http://www.amazon.co.uk/D-Link-1005D-port-100Mb-Switch/dp/B0000687B6
2.http://shopper.cnet.com/switches/d-link-des-1005d/4014-6432_9-32550728.html
check out those link but i was also using that switch but it is not upto the level,i must say it is a entry level mini switch;i don't denied that D-Link is a very good company and i am using there seven of their 48 port switch now;but for this particular product;i don't recommend.
hope it will be helpful to you
Dec 08, 2009 | D-Link DES 1005 Ethernet Switch
I can not get my laptop and my ps2 to connect to internet at the same time
hi Lorraine! may i know what type of laptop brand do you have? mac or etc..?
Sep 30, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
2 pc connected but wont allow both on internet at once
Set up both pc's with dhcp. To do this, right click (My Network Places) in the start menu and choose properties. Right click your network connection and again choose properties. Click Internet Protocol (TCP/IP) and then select properties. Choose (Obtain an IP Address Automatically). Then (OK) and again (OK). Do this on both pc's.
Nov 13, 2007 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch Logo
920 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
