Master Products o Mfg. Co. o - Expandi-Matic Posting/Ledger Tray Metal Tab Index, Pressboard, 6 x 9, 25/Pack Logo
Posted on Jan 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WIRING DIAGTAM FOR J12/0015 SWITCH - Master Products o Mfg. Co. o - Expandi-Matic Posting/Ledger Tray Metal Tab Index, Pressboard, 6 x 9, 25/Pack
Level 3:
  • Master Products Master 19,187 Answers
  • Posted on Feb 16, 2013
Level 3:
Answers
19187
Questions
0
Helped
4345981
Points
82261
What is the switch in?
Hi audi a3 2.0t bwa two faults p2127 and p2122 what can cause this problem
code p 2122 has three reasons
1--accelerator pedal position (APP) sensor---switch D--low input==causes wiring short to ground --APP sensor /switch
2---throttle position(TP) sensor /switch D--low input===causes ---wiring short to ground--TP sensor/switch
3---engine control module (ECM) idle control---high input===causes --wiring short to positive ---TP sensor---ETS control module
code p 2127 refers to APP sensor--switch E--low input===causes wiring short to ground --- APP sensor/switch
also refers to TP switch E--high input====causes wiring short to ground ---TP sensor switch
Starter, alternator wiring diagram
Would need to post year make and model for a diagtam. In all probability when the battery got shorted out by the pulley it damaged the voltage regulator inside the alternator. Make sure all your connections are clean and tight.
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
1helpful
My right tailights are not working after installing a new harness. signal light works and so does brake lights. im looking for a fuse diagtam as there is not one in the vehicle. .
Almost certainly not a fuse. Both tail lights will be on the same fuse. More likely a bad connection at the tail light socket.
Need a video or diagtam on how to wire a 22 hp motor ohv briggs n stratton
That sounds like an accident waiting to happen. If you don't know how to wire such an engine you should not be doing it.
Wiring diagtam for fridgidire dryer--gallary series
I don't see anything to show me what to advise you on. Why are they loose?
Trying to wire a light switch
Copy following link for wiring switches:
http://waterheatertimer.org/How-to-wire-switches.html
Go to the delta website and identify the general type of switch you have. push pull, micro, etc.
Then re-post your question with details about what you are wiring and what voltage you have, and what the switch is rated for.
The key to wiring any switch is to understand what the switch does.
A circuit takes 2 wires to complete the circuit. This is true for all single phase/ split phase household wiring, or for all automobile/ low voltage wiring.
The switch simply cuts one of the wires, and since the circuit no longer has two wires, then the circuit turns off.
The switch usually only turns off one of the wires and not both.
Some switched will turn off one circuit at the same time they turn on another switch. So wiring usually depends on the type of switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Need repacemenistep by step diagtam on for to change the rubber bellow on my maytag neptunne front load washer
I found a service manual in which will give you a step by step process. Neptune Manual This will work for a detailed information and future reference. In the reviewing of this manual, the section you will need is section 5, which begins on page 53.
Good Luck and be safe
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
4helpful
I got a trouble code coming up it is f35 what does that mean
The "F35" error code is indicating a problem with the water level pressure switch operation (key#20). There could be a blockage in the air dome or pressure switch hose (key#21). The air dome is located on the back of the tub on the left hand side. (See image below) If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch see diagtam below for key numbers
13helpful
3answers
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Top Master Products Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Master Products Office Equipment and Supply Expert? Answer questions, earn points and help others
