Question about Dishwashers
Diplomat Dishwasher ADP8322
Dishwasher fills with water and also drains water but during cycle no water is coming out of the spray arms? I have checked that they are not blocked with debris and also had the circulation pump out to see if the impellor had broken. Seemed ok to me but there was a little movement back and forth on the bit in the middle(!) (magnatised)??
Is it the pump or could it be something else? Many thanks for any advice you can give? Regards Neil.
SOURCE: water not going through spray arms
Have same problem except big motor spins independent of stripped? impeller. tried to reassemble but seems mechanical or adhesive agent misssing from one shaft or the other and the motor spins the impeller (now tight) only to have it slip off again and stop pumping water.
Posted on Feb 04, 2008
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
ngfam1
  • 639 Answers
SOURCE: diplomat adp8322 dishwasher soap dispenser
Dear friend,
ngfam at you service!
If its new your warranty is for 12 months!
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Posted on Jan 31, 2009
  • 423 Answers
SOURCE: dishwasher comes on, fills with water, water
What is the manufacturer and model number of your dishwasher?
Depending on the model and design, the sprayer motor/pump has probably failed and the drain motor/pump is still working.
Recommend you pull the sprayer arm and filter. Look for debris that could be jamming the pump - watch out for broken glass when looking.
Make sure the impeller can spin and is not damaged.
If that does not fix the problem, replace the wash motor / pump or replace the entire dishwasher with an Energy Star qualified name brand model.
Good Luck!
Posted on Apr 01, 2009
Dishwasher
sounds to me like the pump is not working as good as it should . water pressure runs the arms .look for something plugging it
Dec 13, 2015 | Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Diplomat dishwasher recirculating problems
I live in an area with hard water. My spray arms get clogged with hard water deposits. Are you sure the spray arms are clear? Here's a map showing hard water areas in USA http://www.citriclean.net/why-citriclean/
Dec 29, 2013 | Dishwashers
Fdb126rbs2 fills and drains fine but does not
DO YOU HEAR THE MOTOR START OR HUM AFTER THE WATER FILLS? IF IT RUNS CLEAN YOUR FILTER AROUND THE BOTTOM OF THE LOWER SPRAY ARM INSIDE. LET ME KNOW IF YOU HAVE MORE INFO.
Apr 25, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Dishes in upper tray coming out not so clean!
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 09, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
DIPLOMAT DISHWASHER FILLS AND EMPTIES WITH NO PROBLEM BUT.... THE WASHER ARMS WILL NOT TURN AS NO WATER IS GETTING TO THE ARMS TO WASH THE DISHES ANDBODY GIVE ME ANY HELP PLEASE
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Check the manifold as well for clogs.
Another spot will be a malfunctioning wash impeller. i would inspect the wash impeller as well. it is responsible for the flow or water during the wash.
Jun 17, 2009 | Dishwashers
Dishwasher leaves film on the dishes
If your dishwasher is a few years old and just started leaving a film on your dishes there is a filter under the bottom adjitator that you have to replace it can't be cleaned jf
Jun 13, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
Dishes don't get clean. soap still on inside of door. . . water coming up to fill line and hot enough and dishwasher drains after cycle, spray arms are clear. . . help!
Water from the wash arms must be able to reach the detergent cup during the wash. It sounds as though the machine may be over-loaded during the wash and water does not cause the detergent to mix with the wash tank water. Try washing a cycle with nothing in the machine. Does the detergent still stick to the door?
If no, the machine is overloaded. Wash fewer items or smaller items so spray will contact detergent.
If yes, you have probably lost wash pressure. Clean all screens and jets.
Hope this helps,
Kermit
Aug 13, 2008 | Dishwashers
Dishes not getting clean
Yes I had the same problem and just fixed it for $7.00. Did not even had to take anything apart. This is what you will have to do. If this dosen't work then try what these experts are suggesting. Please follow these steps for optimal results. #1 Break off a plastic Tea spoon. #2 Put it in place of a LATCH to by pass so you can watch the operation of the dishwasher.(put down some towels for water spill) #3 start the dishwasher on normal cycle. #4 Pour in Gallon of White Vinegar($2.00) while the Dishwasher is being filled. #5 Let it run through its cycle. After the cycle is complete water will drain out and then actual cleaning cycle will start. Then #6 while the dishwasher is being filled again pour in 48 OZ or bigger bottle of CLR (Calciam Lime Rust) it is available at Meijer, walmart, Rite Aid, Home Depot Ace Menard's etc. for $5.00. sit by the dishwasher and listen for it. if you hear water draining pull and push the water plunger so it won't drain so you don't loose your CLR down the drain. since you have the spoon in the LATCH your dishwasher will always be on so BE CAREFUL when you stick your hand in it. And after the cycle is complete enjoy your NEW DISHWASHER.
Thanks
Kashif.A
Nov 06, 2006 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwashers Logo
142 people viewed this question
Top Dishwashers Experts
