Question about GE Advantium SCA1000H Convection / Microwave Oven
No power on GE Profile Spacemaker II Microwave Oven
I replaced both internal fuses and no luck. MWO internal troubleshooting flow chart says to check voltage at low power transformer on circuit board. How do I do that? I see the transformer on the circuit board with two power connectors located adjacent to it. Do I pull those and test?
If I do have power there, the next step is to test the thermostats. I have four of these. How do I determine if they are open or closed according to the flow chart?
Thanks for any help!!
  • thevarinator Oct 27, 2008
    Mine went yesterday. The problem was in a switch that comes in the the center of the main panel. If I hold in up it powers on until I let it go. After about 3 or 4 tries it finally stopped working al together. The panel will probably cost more than a new one especially if someone installs in for you. Good luck
  • William Miller
    William Miller May 11, 2010
    You're on the right rack, but what is your model number?
  • 50 Answers
SWITCHES ARE THERE FOR A PURPOSE-----SAFETY,,SAFETY...ALWAYS CHECK A MICROWAVE WITH THE POWER CORD REMOVED---YOUR MESSIN WITH A RF VOLTAGE THAT WILL KILL YOU!!!! UNPLUG,,UNPLUG,,,UNPLUG
TRY TO CHECK THE FOLLOWING...SINCE YOU HAVE THE COVER OFF,,LOOK AT THE DOOR LATCHES WHEN YOU CLOSE THE DOOR AND MAKE SURE THEY MAKE CONTACT ON THE DOOR SWITCHES,,3 OF THEM,,,--AN OHM METER IS THE TRICK FOR THIS - SOMETIMES YOU CAN SEE PLASTIC BROKEN ON THE SWITCH ITSELF...ALSO LOOK AT THE COMPLETE SWITCH HARNESS (CHECK FOR BROKEN PLASTIC PIECES) THAT HOLD THE SAFETY SWITCHES...THE MIDDLE SWITCH (MONITOR SWITCH) CLOSES WHEN YOU "OPEN" THE DOOR,,YES "OPEN "THE DOOR AND IT WILL BLOW THE MAIN FUSE..IF IT'S SHORTED.
THERMAL PROTECTORS RARELY GO BAD--IF YOU HAVE A PROBLEM WHERE IT TAKES 25 MINUTES TO COOK A BAKE" POTATOE"--JUST LIKE THE VICE PRESIDENT--THAT'S A THERMAL PROTECTOR..
PLEASE BE CAREFULLLLLL TUNICA
Posted on Oct 30, 2008
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
GE Profile microwave # nm1851dm2bb lost all power while heating something. Could it be the internal fuse? Anything else?
If you're lucky it's the internal fuse. Otherwise, there's not much other stuff besides the fan that's easily replaced.
Nov 25, 2013 | GE Profile Spacemaker Over-the-Range...
Won't turn off. Light on and fan running but not heating. Power off and power on and it works for a while. Now it is just off. No lights on control panel.Power off and on and then it works for a little...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 16, 2010 | GE Profile Spacemaker II PEM31 Microwave...
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave top oven won't heat and there's a smoke smell but everything works fine, the fan, light and clock how do i trouble shoot this.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jk4
Apr 14, 2010 | GE Profile Spacemaker II PEM31 Microwave...
My GE profile spacemaker II microwave oven will not turn on. I've tried a difference electrical outlet - no luck. It's a JEM31SF001 thanks
you may have a bad power supply in the microwave.or one of the thermal cut out has gone bad.
the next thing would be a bad control board.
Feb 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a lound noise and no longer heats
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
GE Advantium SCA1000H Convection / Microwave Oven Logo
396 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
