Question about Adobe Photoshop 7.0 for PC
Programming i can't make logic of some typical problems why. i m week in programming. suggest some ideas for making good programming..
    Sergeant:
  • 306 Answers
Programs are pure logic. Boolean algebra is at the very root of the tree. To better understand your problem you must start at the beginning. Computers 'think' in only ones and zeros. Assembly or machine language organizes those on/off states into registers, makes them functional with instructions, jumps and loops where compilers take those operations to higher levels where they become languages -just like we are communicating. Then applications, like Photoshop, use that technology to do billions of mathematical calculations that could take hours or even years to make a digital picture as you desire. The work required of you is to study the tools that the programmer provide.   When I worked as a commercial artist years ago we did not have computers. Life was slower and so was our progress. Still we had to know about paint and paper, brushes and glue. Today it is layers, masks and filters. Master your tools and you have a trade! If you want to catch a fish what would you think to take with you and where would you go? your friend, Steve Medley
Posted on Oct 19, 2008
I have an old Sears garage door opener 139.663900 that went dead this week.
you sure it has power going to it? the outlet it is plugged into is working for sure?
Jul 17, 2015 | Building Materials
The manual does not help. I'm obviously not understanding them correctly. I need step by step...all I want to do is have my lights come on from 7 pm to midnight every day of the week..they are not...
There is no repair for defective timer.
Sounds like the timer could have a conflicting program.
1) Good idea to test outlet with cheap circuit analyzer to make sure electric outlet is not causing problems for timer electronics.
2) Press reset button on timer face using toothpick to Re-set the timer
This will clear programming and then timer is ready to start over.
You can unplug timer from outlet while programming timer, so buttons and display are easy to see.
3) Open following link for clearly written instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
4) I suggest setting timer program1 ON at 7:00pm, and choose all-days-of-week
And then set program1 OFF for 11:59pm all-days-of-week
Setting to 11:59 pm instead of 12:00 may solve problem.
5) Open following link for Kitchler manual:
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
6) If timer will not program correctly, and electric circuit is clean, then timer is defective.
This timer has 1 year limited warranty against workmanship defect.
I always suggest buying timers at local store because returns are cheaper, and if timer goes bad two years later, you can buy new timer and return defect in new package.
Kitchler is same timer as sold by Utilitec at Lowes, and Westek at Target.
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Kichler PLUG-IN ACCESSORIES - DIGITAL...
Hi Heatman, I have a whirlpool integrated Program 2000 machine APDW/1 which began giving trouble recently with the beeping noise staying going and not been able to move on the wash cycle but by stripping...
Hi Martin,
I would agree with your assessment, if all of the wires are still attached okay....of course I'm sure you already checked that...
so... the logical thing would be the control next...
heatman101
Mar 23, 2011 | Dishwashers
I am getting the P0332 code which is the rear sensor under the intake manifold.Would it damage the engine if I didn't replace it for a few weeks?I have 5.3 flex fuel engine.It runs very good with no knocks...
Typically (although all computers may have slightly different logic), if the computer knows there is a problem with the sensor, it will use a retarded default ignition timing that is less fuel efficient but is safe for operation without damaging the engine. This is known as limp mode. As long as the car isn't knocking, you will not damage the engine, but you may experience reduced gas mileage. OK?
Dec 05, 2010 | Chevrolet Tahoe Cars & Trucks
2004 Passat, 127,000 miles, engine light has been on and AutoZone printed computer report that lists an oxygen sensor. This needs to be echecked by the end of the week. Low cost suggestions?
Sounds about right for the miles. A Bosch Oxygen Sensor will cost you around $61 - A DENSO is about $10 cheaper(NAPA prices). Easy to replace, and If you do not replace you will eat up allot of fuel and also could take out your catalytic converter too.. Good idea to replace it. A shop typically charges around $65 labor plus parts to replace it.
Take Care
Oct 04, 2010 | 2004 Volkswagen Passat
Just recently started shutting down intermitantly?
This is a common problem with Imac G5's caused by failing capacitors on the logic board and/or power supply.
It is fixable, but requires very good soldering/electronics skills. Otherwise the typical response from service people would be: needs new logic board and/or power supply.
Dec 22, 2009 | Apple iMac G5 Desktop
Only opens when remotes are close
The problem is in the receiver on the logic board. You will have to replace the logic board. You can get a replacement part at searspartsdirect.com. Thanks BB
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
WinFax Pro 10.0
I don't know the Operating system you are using but that version, as I remember, had a few problems. Suggest you check to A) make sure it's fully compatible, B) Check the supplier site (Symatec I believe) for issues...(under support), and C) If all else fails uninstall and reinstall. Use Ccleaner to clean the registry before reinstalling (free and you can't make a mistake) and also delete the application folder (typically under program files in an automatic install). Do the latter after using the windows add/remove programs capability. This should do it. If not bug me.
Tango.
Feb 04, 2008 | Symantec WinFax Pro for PC
Half Screen went black
Try to replace the Logic board.
Dec 17, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Adobe Photoshop 7.0 for PC Logo
64 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
