Logitech Cordless Mouse Logo
Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mouse will randomly double click or have to click several times to work
My mouse will randomly double click on its own. I have checked the settings and it is set to 1 click. Then sometimes I have to click 3-4 times for it to work. I have had this mouse for about a year. It just started doing this about a week ago. I have recently changed batteries, that didn't help. Could there be something wrong with the lazer? The mouse has hit the floor several times over the past year (thanks to my felines).
  • Anonymous Oct 23, 2008
    i have the same problem. anyone have an idea of what may be causing this issue? please help..
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Oct 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
18532
Points
13
I'd suggest that you try another mouse, maybe it's too old to work.
For auto clicking, you may also try mouse clicker software. Find out how to use auto clicker from here.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
18332
Points
Get a new mouse, i got mine today
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 19, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6206
Points
You mouse may be too old, the switch inside will get worn over time making signals to your computer worse.
I had the same problem with my Logitech mouse after only 5 months of use.
Click less with: http://autokeybot.com :-)
Anonymous
Level 2:
  • Expert 258 Answers
  • Posted on Feb 01, 2009
Anonymous
Expert
Level 2:
Answers
258
Questions
0
Helped
138742
Points
619
Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
You could also try going into Control Panel --> Mouse
Try Slowing down the double click speed
If that doesn't work try speeding it up
Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
Double clicking, left button
Hello, if the mouse is double clicking randomly means the mouse button or button soldering are broken, maybe you might want to try opening it up and resoldering the mouse button, if it doesn't work you can use an old mouse button that fits the space and solder that one in the mouse that's having problems, reassemble and see if it works, the good news is that most of the time it does.
I have a manhattan wireless mouse, model number 176811. the pointer works fine but when i double left click to open anything nothing happens, i have to hit the button 3 or sometimes 4 times to open file??
You may not be double clicking fast enough. In the Windows System Control Panel, there is a Mouse Settings control panel. You can adjust the double click rate in the Mouse Settings control panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
This mouse worked fine for several weeks. But then, suddenly, it developed "rabies." When I single-click the left mouse button, it almost always treats it as a double click. I did slow down...
Mice and keyboards only last so long. Some are better than others; however, its time to get a new one. I suggest you put up about $30 and get a Mouse/Keyboard Wireless set. No wires and no fuss.
1helpful
Double tapping feature on my touhpad seems to have got disabled. Pl advise how I can enable it
Go to start, control panel and look for the mouse. Double click on the mouse and a window with several tabs will open to change the settings on the mouse, including single and double click,
I hope this information was helpful.
Brian
When i click on any icon, cpu doesnt follow through with the double click command
There's several possibilities as to why this is happening.
The first is that you may be moving the mouse some as you are clicking, when this happens windows registers this as two single clicks. Depending on what mouse and drivers it will be different. Go into "Control Panel" then select "Mouse", find the setting for "Double Click" (most likely under buttons, maybe another button of some sort to access this feature). Once you have it up depending on make and model you'll be able to adjust the settings for "Double Click". Make adjustment and test them in the "test area" until you have what you need.
Second, if you have a 3 button mouse set the center button to "Double Click" and use it to avoid this problem.
Third, Windows may be causing the problem by doing maintenance task in the background. This is usually caused by Windows adjusting your Virtual Memory. To fix this go into "Control Panel", choose "System", goto the "Advanced Tab", choose "Settings", goto this "Advanced Tab", under "Virtual Memory", choose "Change". Once there choose "Custom Size" then set "Initial" and "Maximum" to the same size, this size should be 4 time your RAM plus 12MB or the the current Max whichever is larger. Select This will stop windows from constantly adjusting your Virtual Memory, which is what makes Windows not respond to your double clicks. If you need further help respond to this solution and Fixya.com will notify me and I'll try to help you further.
Mouse left button double clicks all by itself about every other time it is pressed. Very annoying. May be an internal contact problem, but don't know how to open it up to check.
Recommend you check your mouse settings on your computer (i.e. mouse properties buried in control panel settings as found on Windows XP); make sure double-click speed is not set at an over-sensitive setting.
Might also check there is nothing sticky under the mouse key, causing it to get stuck (e.g. splashed soda pop or something that got under there).
1helpful
Mouse keeps double clicking even when I click one time. I've checked in the control panel under the mouse settings and it should be fine where it is at. But 90% of the time when I click an X to close a...
You checked the settings. Most likely the micro-switch in the mouse is "bouncing" which means the output of the switch contains noise that is interpreted as multiple
closures. This means the micro-switch is worn out...
You can reverse the left and right switches in the control panel and if the right button works without adding ghost clicks then you just need to get a new mouse...
Good Luck
2helpful
2answers
Mouse sometimes double clicks so that it opens 2 things at a time, what is causing that. It also seems to be sticking I have to press it a couple of times to get it to click
You need to go into the control panel and choose the mouse icon.
From there you can set the double-click speed. They give you a little box to click to calibrate the click speed.
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
MSI mouse thats included in MSI S420
you need to check the mouse settings, go to Start>control panel>printers and other hardware>mouse and check that it isn't set to one click as being a double click, check all other settings also especially the click speed may be set too fast and is encouraging a double click.
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
