Question about Orion 2500D Car Audio Amplifier
How to fix a popping sound
When I turn on my amp it causes the subs to pop, not loud or hard but low and soft repeatedly. When it does this the protection light comes on and goes off. What would cause the amp to do this and how can I fix it?
  • David Layne Jun 09, 2006
    Its not normal for the amp. It seems to be turning on and off, one second its on and the next its off. And it just keeps doing it on, off, on, off. I had it sent to Orion and I was told it would cost $400 bucks to fix,(by the dealer) I never talked to Orion yet. I know its not the wiring, because a: I checked everything b: I hooked up a Mark Anthony 3000D, without changing the wiring. I had the Orion hooked up for about a year and it pounded the h*ll out of my subs(first 2 Directed 15"s, then 4 directed 15"s, then 2 Kicker 15"s L5's(they lasted less than 6 hours), then the 2 Kicker 15"s L7's I have now).
    President:
  • 3,130 Answers
This problem could be a normal thing in the amp, or there could be a problem in the muting circuit. I would contact the manufacturer to check with them , if theres any common issues with this amp. Also I've seen custom car amp installs where you hook up a speaker delay circuit that you can build from a few parts like a couple of capacitors a few resistors , a 555 timer IC and a relay with high current contacts. I have also seen these already factory nmade in good auto stereo shops. Good Luck
Posted on Jun 08, 2006
How do I replace a subwoofer potentiometer ?
If the 10k resistor is the variable volume one then change it.Some sub amp plates have epoxy all over the pcboard.Hard to remove type.I think yours is soldered to a sub pcb and need soldering experience to remove.
Sep 14, 2014 | Polk Audio PSW111 Speaker
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
I just got this bass and am getting speaker pop at low frequencies, any ideas of what is causing this? All other frequencies sound great.
If you are driving the speaker too hard it will pop. This caused when the voice coil is driven mostly beyond the pole pieces of the magnet. Without the magnetic field the back EMF of the voice coil drops off and the current shoots up. The voice coil can't move farther so there is a discontinuity of movement which causes a pop.
200 watts is a lot to put into a 12 inch speaker so you have to be careful to not drive low frequencies at excessive volume. It is both very hard on the amp and doesn't do the speaker any good either.
If you want loud lows, you should get a subwoofer of at least 15 inch speaker to handle the lows.
Aug 04, 2010 | SWR Workingpro 12 200watt 1x12" Bass Combo...
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
Unwanted bass coming out of my subs
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Feb 24, 2009 | Kenwood eXcelon KAC-X812D Car Audio...
KAC-9102d no sound, Amp powers on but no sound to the subs.
If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
Feb 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Popping
If you Wire the 13 w7 in parallel you get 0.75 ohms which this amp is incapable of handling, that's why your speaker is popping. Be carefull cause this setup could ruin both your amp and sub. You have to wire that sub in series so that the amp "sees" a 3 ohm load which it's best suited for.
May 28, 2008 | Jl Audio 13W7 Car Subwoofer
At high volume sound shuts off, subs still work
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Dec 08, 2007 | Pioneer DEH-2100 CD Player
Amp makes subs pop
It sounds like your amp chip has gone bad, here is some thing you can try turn on your unit then start tapping on top of with your finger not hard see if the any of the pops matches your finger taps some times when the chip starts to go out it well act like that.
Nov 04, 2006 | Orion 2500D Car Audio Amplifier
Orion 2500D Car Audio Amplifier Logo
1,005 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Morne Olivier
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
