Television My screen on television went black with a white horizontal line going through it. Still have sound. T.V. is only 3 to 4 years old. What could the problem be?
This is not a DC power supply problem. You most likely have a fault in the Vertical deflection circuit of your TV. You will need to get a qualified technician to look at this.
Posted on Oct 29, 2008
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
No Picture On Screen
it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
No picture or sound.
http://www.vancebaldwin.com/models/?TBA53AX61
Part Number Decription 23236623 #T461 FLYBACK TFB3086AD 24083013 #Z401 NOTE **SEE 50A61 FOR MAIN PARTS LIST ** 23549258 BEZEL 23427995 DOOR 23905094 IC STK392110 23311899 LENTICULAR SCREEN 23405040 MIRROR 23565302A OWNERS MANUAL 23311859 PROTECTIVE SCREEN 23306370 REMOTE 23311892 SCREEN FRESNEL CDSMPJTV03 SERVICE MANUAL (CD) 23527210 SPEAKER GRILLE
Feb 03, 2008 | Toshiba 53AX61 53" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
