Question about Microsoft Windows XP Professional
Connect an Hp laserjet printer through a card : pcmcia/2 parallel ports
My windows xp system can't recognize the Hp laserjet printer 1100 when I connect it to my laptop through a pcmcia card which converts pcmcia bus to two parallel printer ports. I think a driver is missing, windows installation wizard can't find it on the internet.
  • 42 Answers
Hi check out the following link...
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Hp+laserjet+printer+1100&submit.x=0&submit.y=0
I was not sure if yours is Hp laserjet printer 1100 or Hp laserjet printer 1100se or Hp laserjet printer 1100xi... or the all in one series....
Just check out the model... from the site the link takes you to choose the appropriate printer model... then select the Operating System you use and then download the driver...
I just wanted to be doubly sure that you gave the right printer model... Just in case...
Am sure this link would have taken you to the driver you were looking for...
If the problem still persists after downloading and installing the appropriate driver just leave a comment i will check it out...
FixYa!!!
Posted on Oct 18, 2008
  • Hariram Shankar
    Hariram Shankar Oct 24, 2008
    may i know why you have given me this rating?
I bought a new HP computer and it didnt have a serial port included in it. I purchased a secondary PCI Express card that gave me two serial ports. They are programmed in as com port 1 &2. They show...
Serial connection eh? Any reason you went with serial instead of parallel? The cards likely sell for about the same price or you could just buy a USB to parallel cable that would allow you to hook up a USB port of your computer to the parallel port on the printer.
The reason that it looks like the job disappears is likely due to the fact that the serial bus is not supporting bidirectional printing so the printer cannot acknowledge that it has received the job.
Apr 19, 2011 | HP LaserJet 5 Printer
I installed the laser hp 1100 on windows xp
Your problem is your PC parallel port is not configured or turned on. I would first look in the control panel, device manager and see if you have a parallel port listed and it does not have a yellow or red sign on it. If red or yellow then it is on but not configured. See below for that solution.
If it does not appear, reboot your PC and enter the bios. Find the setting for the parallel port and set to enable. If on you can change the setting on what type of parallel it is emulating. Normal is bi-directional IEEE.
Then save and restart to go into Windows. Test and print.
OK, if the parallel port in the DEVICE MANAGER shows a yellow or red sign on it, it has a bad driver, or bad settings. Un-install the port by right clicking and choose UN-INSTALL. Restart your PC and it should find the parallel port and install it again. Hopefully without the yellow or red sign on it. If the red or yellow sign is back. Look on the internet for the newest driver for your motherboard.
As a note: if you are using a print server or USB to parallel adapter these solutions won't help. You will have other issues to address.
Good Luck
Dec 17, 2009 | HP LaserJet 1100 Printer
Hp laserjet 1100 - won't print under Win'98SE i've got this printer and can't use it on a computer under win98SE. under XP works fine! all the ports seems to be bussy, and request to increes the timeout...
Try changing the LPT port mode in the BIOS- there should be like SPP, EPP, ECP. As I recall there are different drivers for USB and Parallel and I don't think Serial is supported. If you installed HP drivers, Uninstall and use the Windows drivers.
Dec 07, 2008 | Office Equipment & Supplies
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
HP1100
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
Jan 15, 2008 | D-Link DP-G321 Print Server
Microsoft Windows XP Professional Logo
200 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
