Question about Compaq Presario Notebook
Mic i checked it but dosnt work and i try to record but nothing
  • 905 Answers
Ensure the correct recording device is selected To access the sound properties, follow the steps below.
  1. Click Start , Control Panel , Hardware and Sound , and then Sound . The Sound window opens.
  2. On the Playback tab, select the SPDIF Interface, or audio device.
  3. On the Recording tab, select the Audio device that is installed on the computer. It should be the same as the listing under Sound Playback.
  4. Click OK , and then close the Sound window.
Try recording again to determine if the problem is resolved. If there is still no sound, continue to the next step.
Posted on Oct 18, 2008
  • jason Oct 18, 2008
    xp don't have a tab but it does have a button select to choose between playback and recording to select a device to choose from ( for recording )( check the mic. and save then see if you can record )
Built in mic not working
It looks like you installed a program (one that uses audio) that uses different settings for audio. If this is the case; go into that program and go to preferences or advanced settings etc and disable the audio and change it to default audio.
If not let me know :)
Oct 27, 2013 | Fujitsu Computers & Internet
Mic dosnt work in dell optiplex
Go into the Audio Properties and set the mic as a recording device.
Click Start/Control Panel and look for Audio or Sound. Go through and find where you set the microphone as a recording device and put a check by it.
You can also click on the megaphone at the bottom right near the time to get into the Audio Sound Properties.
May 27, 2012 | Dell Computers & Internet
Mic dosnt work
May 27, 2012 | Dell OptiPlex 360 Desktop Computer
Im trying to play music through my sound card and talk on the mic in paltalk i got SB1090 and it sitll dosnt work
try going to Start>Control Panel>Sounds,Speech, and other Audio Devices>Sounds and Audio Devices>click on Voice tab>go to Voice Recording,Default Device and change it to your current device.
Oct 15, 2009 | Creative Labs Sound Blaster Live! 5.1...
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
May 15, 2009 | HP 510 Notebook
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Nx7010 mic problem
Did you check the sound settings for the mike?
May 08, 2008 | HP Compaq nx7010 Notebook
Hello, I have an Iphone 1.1.4
ok attila, your problem is your mic,, here's what they are going to do..(the pro's ) open your fone and in the lower section where the mic and the contact point located. they are going to test it if the mike is still ok, if it is ok, they're going to clean it with solutions u'r mic and contact point, and it will going to work out fine, but if not they have to replace u'r mic...
Apr 21, 2008 | Cell Phones
Why my mic dosnt work on yahoo chat
zzzdisk
It is a general problem, you have to see on control panel, and see if the correct drivers for the particular modem is well installed. Also check your conection again, (settings) for your TCP/IP configuration, and dialup? set up.
check your drivers for your modem too, and if you set up correctly the Messenger, on setup the mic,cam, and sound.
good luck
Nov 26, 2007 | Audio Players & Recorders
Help please
check the settings on your msn that the input is set to the mic and also on the sound in control panel that input is set to labte mic
Sep 30, 2007 | Labtec Webcam Pro
Compaq Presario Notebook Logo
136 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
