Question about Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W black 19 inch LCD
I have a Gateway FPD1975W black 19 inch LCD it seems to be in a test mode it keeps flashing a colored screen then a grey one then black not sure why any help would be great thank you
    Genius:
  • 1,605 Answers
Most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Posted on Oct 20, 2008
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
When i plug in my Gateway FPD1975W TFT LCD Monitor, the screen stays black and the power button blinks. This goes on for hours without doing anything else. Suggestions?
If you have this connected to a computer and it happens,make sure the fault is not with the graphics card or port first. Test the monitor on another computer or laptop. Test and check the VGA cable.
If this is not the problem (ie the monitor will not work on another computer and another monitor will work on your computer), you are probebly having power capacitor problems and the monitor needs replacing.
This link will explain more
http://en.wikipedia.org/wiki/Capacitor_plague
View sonic monitors were particularly known for this problem
Aug 16, 2011 | Gateway FPD1975W 19" LCD Monitor
(small text) color is off -- it looks green while should be black. I am looking for a timing table for Gateway FPD1975W. Thanks
mcdevito75 here Try to press the AUTO button on the monitor to restore factory settings to monitor.
Jul 21, 2010 | Gateway FPD1975W 19" LCD Monitor
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
FPD1975W (Black) 19 inch LCD Monitor: power button flashes but not coming on...
Open the cabinet and remove CMOS battery and harddisk connection from motherboard.
And reboot the system. It will give the msg no boot device found. Now place again the cmos and harddisk and reboot
May 06, 2010 | Gateway FPD1975W 19" LCD Monitor
My gateway FPD1975W 19 INCH LCD MONITOR DOEN'T TURN ON, THE SCREEN IS BLACK
First place to check will be the power supply, look for bad caps with bulging tops or bottom seall first and report back what you find then we can guide you futher, see what bad caps look like here:
Jan 27, 2010 | Gateway FPD1975W 19" LCD Monitor
Display will not come up, screen remains black, blue light on front of monitor flashes on and off
Check that the monitor is still receiving a signal it could have gone into standby mode.
If not you either have a faulty inverter or the back light has gone, to test this when your computer is on is to check you can still see a faint image on the screen that means the backlight has gone, if not its the inverter.
Jan 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Connection?
check the videocard. remove it and place it again if no improvement try to connect monitor to another system. If no color, replace monitor.
Nov 03, 2009 | Gateway FPD1975W 19" LCD Monitor
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
230 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
