Question about Directed 1100d Car Audio Amplifier
REASON FOR LOSS OF POWER
THESE AMPS ARE MADE TO PUNCH,BUT ONE NIGHT I WAS RIDING AROUND ON MY CELL, AND FORGOT THAT THE AMPS WERE ON WITH THE RADIO TURNED DOWN. THEN AFTER ABOUT 1.5 HRS, SMELLED A BURNING SMELL, SO I DROPPED MY BACK SEAT AND SMOKE WAS COMING HEAVILY FROM THE AMP. IT STIL WORKS , BUT SOMETHING IS FRIED!! SO IS THERE SOMETHING THE I CAN BUY AND FIX MYSELF BY SIMPLY SOLDERING OR SOMETHING.
    President:
  • 3,130 Answers
If it still works then all you did was over heat some bias resistors and they probably will weaken and go bad eventually and could cause your outputs to go south also. I would get this puppy into a shop asap unless you wanna lose the amp or a good possiblilty. Good Luck
Posted on Jun 08, 2006
I have not been around to drive my 1999 lincoln towncar and now i am and the radio doesn't work anymore does it run from a fuse? and where is it located?
  • The fuse panel is located below and to the left of the steering wheel by the brake pedal. Check the fuses I have indicated in the diagram below as they all are connected to the radio in some way or another.
  • 18 - 7.5 Amp - Lighting Control Module (LCM), Front Radio Control Unit, Cellular Telephone Transceiver, Electronic Day/Night Mirror, Compass Module
  • 24 - 5 Amp Front Radio Control Unit
  • 33 -15 Amp - Front Radio Control Unit, Digital Compact Disk Changer, Cellular Telephone Transceiver.
  • The power distribution box is located in the engine compartment. Check the #19 - 30 Amp in there as well. This powers the Subwoofer and I suspect the amp as well.
  • Hope this helps.
Nov 14, 2011 | 1999 Lincoln Town Car
Bought Punch Home & Landscape Design Premium at
The reason of the error 1305 is a bad download or a bad disk
Try to contact Punch TD or try to download your file again
If the problem persists, contact directly with Punch
http://support.encore.com/ the best resources for Punch Software solutions
Punch Software Community Forum
Punchhelpers Website
Learning Punch Software (R): Basic & Advanced Training
Learning Punch Software (R): Importing, Exporting and Printing
Punchhelpers at Faceboo
Aug 13, 2011 | Punch Home & Land Design Nexgen for PC
Fried 3 amps. Is it my car? 93 mustang gt. I had my original amp Rockford Fosgate punch 500@2 for about 8 years then the whole system got stolen. Bought the same one on Ebay and it was fine for a few...
make sure you run your ground and power wires on one side of the car and the rca's on the other, keep them sepparate. if you have all wires running to your amp(rca's/12v power/remote), then you run the chance of either getting interference from the alternator, or if you have a pinched wire(usually by the door step) it may short with your battery wire. Double check your rca's and make sure they're ok and also check for corrosion on your wires.
Jul 05, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
Rockford Fosgate Punch 500a amp wont turn on
check the internal fuses inside the amp its self these burn up real easy plus if it is them it will save you some money
Mar 31, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
Power and ground are good cant get amp to turn on
Don't forget the most inportant one, the remote wire!!!! It tells the amp when to turn on/off. Should be connected to your aftermarket radio amp or power anteanna lead (should be blue). If running a factory radio you can use the radio fuse power to provide a signal to it..
Oct 26, 2009 | Rockford Fosgate Punch 120.2 Car Audio...
Hello. I have a punch 551 4 channel amp. The
The cost of the replacement parts is minimal if there is no damage to the audio circuit. If there are shorted output transistors, the cost of replacement parts won't be significantly higher but it may be more difficult to repair. If you're going to try to repair it yourself, read through the following page:
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Jul 18, 2009 | Rockford Fosgate Punch 401S Car Audio...
I have been having trouble with my car stereo system
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Aduz
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
Remote wire hook up
The Remote wire should connect to the remote turn on lead from you radio(most aftermarket radios use a blue and white or a blue wire for the remote turn on). This wire will send a 12v signal to the amp from the radio when the radio is turned on. You can disconnect the remote turn on lead from the amp and jump a wire from the terminal marked battery to the remote turn on terminal just to see if the amp powers up. Do not leave it this way however because your amp will not shut off and your battery will go dead.
Aug 19, 2007 | Rockford Fosgate Punch 301S Car Audio...
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Directed 1100d Car Audio Amplifier Logo
48 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
