Question about Hitachi Cameras
I have an Hitachi HDC-55IE camera but cant delete any pictures from my memory card because it says they are locked,how do i unlock them?
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Hitachi HDC-I49IEP how to delete pictures
Try formatting the card using the option in the camera itself. or take the card out and put in laptop / PC using the card reader and try formatting the card.
Apr 13, 2014 | Hitachi Cameras
Cant get my camera to download pictures
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 14, 2012 | Hitachi Cameras
What does it mean when it saids your memory card is lock I haven't lock it.Please help Thank You
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 07, 2012 | Panasonic DMC-FZ35 Digital Camera
Protected card on camera?
your card is probably locked take out the memory card and on the side is a lock tab slide the tab to unlock when you put it in your camera it may say format card when you do this it will format the card but will delete any pictures saved to the actual cameras memory so save them on your computer or print them.
Mar 20, 2012 | Hitachi i.mega HDC-401 Digital Camera
Hitachi hdc-651e digital camera memory card locked and cant unlock
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 14, 2010 | Cameras
The card, or memory chip in camera is locked, and i dont know how to unlock it, so now i cant take pictures, or upload my pictures, or even delete photos,i just need to know how to unlock my camera.
This used to happen when the write protect lock on in the memory card. Refer the manual to see how to remove the memory card.
After removing the memory card, unlock the write protect tab as shown in the fig. d7656e6.jpg
Apr 20, 2010 | HP Photosmart M547 Digital Camera
Card locked
move slider switch on side of memory card to unlock card
May 16, 2008 | Samsung Digimax D53 Digital Camera
Cameras Logo
48 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
