i-Bulldog IMP-90  MP3 Player
Problem for i-Bulldog IMP-90 (256 MB) MP3 Player
HOW DO YOU FORMAT??
By wildchild692 on Jun 08, 2006
How do you format?
Same Problem
Jan 09, 2008
-   Iv added songs to my JNC 2 gig mp3 player bt wen i tried to play them it reads empty disk.i plugged it in to my pc nd there isnt a virus so i thought reformatting would help.i tried wit windows XP bt i cant, it says its write protected.
wt do i do?-   Guest
Nov 05, 2007
-   Ive tried to erase the file with the virus but Ididnt succeed-   Guest
Best Solution
posted on Feb 09, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The solution to format through windows seems to be a poor solution. Most of the time this does not work. Something helpful would be appreciated.
Solution #2
posted on Feb 05, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a problem on my lapatop, Engine Error, also Error message, End Now and also its very slow. It Freezes. I was told to format and save everything, and then delete everything and reinstall all with disk that came with my laptop. How do I format before saving and deleting. Thanks
Solution #3
posted on Aug 27, 2007
Very Helpful)
Apex
Rank: Master
Rating: 81%, 20 votes
http://www.lenoxx.com/2005/mp3player/mp5...
if you have a ilo model mp-556 (on the back cover) this page has links to the firmware and manuals etc... i follow the instruction and got mine working.
u might need to use the reformat as well as the upgrade firmware to make your list read the same. reformating will set your storage area back to factory specs. i e delete all your songs on your player
Was this helpful?
Yes
No
Solution #4
posted on May 22, 2007
Very Helpful)
Keano
Rank: Apprentice
Rating: 95%, 2 votes
I've used a flash card adapter and it asks me to format it, but all i want to do is get all the music from the hard drive to the computer but i cant do this because it wants me to erase all the data.
So if i just format it Ghostman, will it actually keep the data?
Was this helpful?
Yes
No
Solution #5
posted on Feb 19, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try changing it to MSC (I believe), then plug in the mp3 player, go to My Computer, and right click the drive with the Sansa on it. Go to Format, click "Start", and voila! That SHOULD work if it won't work in MTP.
Solution #6
posted on Feb 10, 2007
Helpful)
madicker
Rank: Apprentice
Rating: 91%, 5 votes
I've tried to erase files and format my Creative sony MP3. The files I erase either never permanently are deleted off drive or I get the message "Windows was unable to complete format." Is there anything I can do or is the MP3 good no more?
Was this helpful?
Yes
No
Solution #7
posted on Oct 01, 2006
Helpful)
GHOSTMAN
Rank: Apprentice
Rating: 84%, 54 votes
ghost... indicated that his solution for
PSA220 (256 MB) MP3... Problem
is valid for all MP3 and Digital...
I've tried to erase files and format my Creative Nomad MuVo MP3. The files I erase either never permanently are deleted off drive or I get the message "Windows was unable to complete format." Is there anything I can do or is the MP3 good no more?
Was this helpful?
Yes
No
Solution #8
posted on Jun 09, 2006
Somewhat Helpful)
soldierruel
Rank: Wiz
Rating: 75%, 872 votes
Go to my computer and right click them seclect format.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #9
posted on Feb 04, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
first of all u need to download a compatible format with your player. In this case installing the firmware might help. then go to your driver and right click then select format.
Solution #10
posted on Jan 17, 2009
Somewhat Helpful)
RALilja
Rank: Wiz
Rating: 80%, 60 votes
The symptoms of lots of extra folders, undelete-able files and folders, not able to add files or folders, wrong size of files reporting and other wierd problems are due to the File access table system being corrupted!!!
What you have there is an mp3 player that the files area on it is corrupted and the pc nor the player itself may be able to fix it via a format.
What needs to happen is for you to use the pc and right click on the player and select PROPERTIES. In properties you need to get into TOOLS, then use the ERROR CHECKING function to repair the file system of the player. Make sure you check off the 2 boxes in the next window that appears to automatically fix the file system, and to scan and attempt recovery of bad sectors also!
Once the above is completed you might as well do the defrag function also for the player to make it run smoother.
Hope this helps.
Rich Lilja
Was this helpful?
Yes
No
Solution #11
posted on Jul 24, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i had a load of strange files in one of my albums on the mp3 which i couldnt delete or move, and they stopped it from switching on fully (just came up with the welcome screen)
I've just formatted it like soldierruel and now its clear! i can replace all my music!
Thanks! xx
Solution #12
posted on Mar 05, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
http://www.themp3players.com/archives/20...
That provides a link to the ilo firmware needed to
get it to work, and instructions on how to use it.
It fixed my ilo (Note: when the instructions say you may have to update it 2 or 3 times, I had to do it 3 times before it worked again.).
Solution #13
posted on Mar 01, 2007
Not Rated)
LaSuperChica
Rank: Apprentice
Rating: 0%, 0 votes
Of you want to format you Ipod without deleting the files from your pc, just uncheck the box "sincronize" of whatever file you want to delete.
breNda
Was this helpful?
Yes
No
Solution #14
posted on Feb 21, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi , I do not own a Creative Nomad MuVo MP3 but normaly (with generic Memory based MP3 players) you can do it in Windows (on your PC).I would try FAT and not FAT32 format.
Very often it is better to use the FORMAT function in your MP3 player.Good luck.
Popular Solutions for i-Bulldog IMP-90 MP3 Player
Questions and Unsolved Problems for i-Bulldog IMP-90 MP3 Player
Do you recommend i-Bulldog IMP-90 (256 MB) MP3 Player?
Answer
Answer
I have a i>bulldog mp3 player and I don't have a cord to download music, do you know were I... (More)
Answer
In model BF-100, It does not charge, an can only read: non icon &font usb only down load to... (More)
Answer
my sandisk e250 has a very low storage space after formating the device how do i get the right... (More)
Answer
i am trying to find a user manual for the i-bulldog mp3 player. would like to download from a free... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For i-Bulldog IMP-90 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 480
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
