Question about HP LaserJet 3600n Printer
HP 3600n Cartridge Memory Tag
We have a HP 3600n color laser printer. The black cartridge (Q6470A) ran out. A local business said that they could refill it. They did ad I reinstalled it. The screen on the printer says "Replace Black Cartridge" Error 10.10.00.
I know that it is something to do with the memory tag on the back of the cartridge. I have tried the usual procedures of removing the cartridge closing door, opening door, reinserting, restarting, etc. etc. already but that doesnt work.
Is there anyway to reset it - like perhaps the Service Code menu?
  • dnlmartin Jan 09, 2009
    The toner cartridge still has lots of toner in it but printer won't allow it to print more pages. How can I over ride the memory tag?
Check the latch on the right side of the black cartridge. They have a problem with them breaking. There is a new style available.
Posted on Oct 20, 2008
Hello I have a problem with the work printer. It is a 3500 hp color laser jet and it is having a 10.10.00 supply memory error. I'm not sure what to do. Can you please help me?
10.10.00 SUPPLY MEMORY ERROR
Missing memory on supply
Black print cartridge
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color indicated with a cartridge in another slot to determine whether the error follows the cartridge or stays with the slot. If the error follows the cartridge, replace that cartridge, otherwise, continue with step 4.
4. Check the memory controller PCB contacts to the memory tag. Clean if dirty.
5. Reseat the memory controller PCB connector J201 and DC controller PCB connector J1025.
6. Defective memory controller PCB, replace the memory controller PCB.
7. Defective DC controller PCB, replace the DC controller PCB
Aug 25, 2011 | HP Color LaserJet 3500 Printer
My hp 3505dn printer prints a full page coat of black over the print job
Black toner cartridge failure, replace it for another (Q6470A) and try print.
Jul 22, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
I ran out of black ink, can i still print with my other colors?
If one of the cartridges are empty these printers will typically stop and demand a new cartridge. If you are lucky enough to be able to still print then go for it.
May 23, 2011 | HP LaserJet 3600n Printer
I installed new cartridges (4 colors (B, Y, M & C) and closed the top cover, it calibrating continuously for a week and more. So, please help me to solve this issue. My printer model is HP Laser Jet...
Hi I'm sorry to say its normally a faulty cartridge.
You now the black belt in the front of the machine well the machine when it calibrates prints a pattern on the belt and it uses this pattern to calibrate its self but if the pattern is not on the belt it can not finish the calibration.
solution replace the toners one at a time until you get it going
yours Ian
Mar 08, 2011 | HP LaserJet 3600n Printer
I have an HP Color Laserjet 3600n with error 10.10.03
Thank you for contacting FixYa with your printer issue.
www.hp.com Support Document (110993)
10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
  2. Remove the print cartridges, and then reinstall them.
  3. Close the front door.
  4. Turn the printer off and then on.
  5. If the error persists, contact HP Support.
Helpful CLJ 3600 Error Message Tables:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00047478&prodTypeId=18972&prodSeriesId=501044
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 22, 2011 | HP LaserJet 3600n Printer
No writing on the right side of the sheet with black and color faded out on same side with color
if i read this correctly both color and black are missing from one side?
this is most likely a problem with the belt.
if it was just 1 color or black it would be that toner/drum cartridge or the laser associated with it.
http://www.precisionroller.com/belts-for-hp-color-laserjet-3600/details_45933.html
for non duplex
and
http://www.precisionroller.com/belts-for-hp-color-laserjet-3600/details_45935.html
for duplex model
Jan 19, 2011 | HP LaserJet 3600n Printer
HP 3600n color printer only printing solid black page. cartridge is fairly new. what is the problem?
defective cartridge or problem whit laser/scaner assy - replace cartridge ( to solve this just turn back your old cartridge and try to print something to be sure before you buy new one) - visit HP servise for laser/scanner assy
Sep 29, 2009 | HP Color LaserJet 3500 Printer
I am getting 10.00.01 memory supply error on the cyan cartridge of my HP color laserjet 3500. The cartridge is nearly full and was working fine. I have tried cleaning the memory controller PCB contacts but...
I had a like problem and found that the chip on the cartridge was mounted without enough spacer such that contact was not being made with the memory controller PCB connector.  I cut some two-sided tape and put it behind the chip such that it stuck out further so that better contact could be made and the problem was solved.
Apr 28, 2009 | HP Color LaserJet 3500 Printer
HP 3600N Printer 10.10.01 error
1. Open the front door.
reinstall them.
Mar 30, 2008 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
582 people viewed this question
Seeker5211
Seeker5211
