Question about Epson Stylus Pro 10000CF InkJet Printer
Epson 10000cf 00020000 error how to fix??
I have a epson 10000cf 44" archival printer..I transported the printer, later plugged it in and all the lights are flashing. Cannot get anything out of the printer besides flashing lights. I have the service manual, and it describes NVRAM fatal error. This RAM I'm guessing holds the printer bios. I wonder by removing and replacing the battery on the board would reset the NVRAM. If not how can I get past the flashing lights and reset the NVRAM. And by the schematic I can't determine if the the NVRAM is on the mainboard or the drive board. The mainboard is around $300 to replace, and the drive board is around $1000 to replace. Any ideas. Maybe does anyone know if there's a place I can send the board to be fixed?? I am a small printing business, and this is taking a big hit on me right now..Anyone have any logical ideas?? Also can't figure out how to load new firmware without the access ??? Help!!
  • jaydokken Feb 05, 2009
    I have an epson stylus 7000 with the same error. From my point of view there is no way to fix it short of replacing the main board.
    -j
Basti
  • 1447 Answers
SOURCE: Epson Pro 7600 Service required error
If you are getting that error try this
Check to make sure the locking bracket and screw have been removed from the print head.
Turn off the printer.
Open the lower cover on the front of the printer and remove the bracket and screw holding the print head in place.
Close the printer cover and turn on the printer.
The Pause light, begins flashing and the printer starts charging the ink delivery system.
If a different error then update me, thanks!!
Posted on Apr 17, 2008
Inky
  • 691 Answers
SOURCE: epson cx 2900
If the error is fatal then there is NOTHING you can do at home to sort the problem out. If Epson are refusing to repair the unit because you have repeatedly used non genuine ink then you can try and take them to task on the legality of that decision (depending upon consumer law in your area) but the chances of you getting it sorted without costing a fortune are slim to none.
There is an error which shows up in the status monitor as MAINTENANCE error and this can fixed relatively easily. It's symptoms are similar. However, a fatal error is generally just that - Fatal - and there is nothing the home user can do as this generally requires parts fitting.
Your non genuine ink is almost certainly NOT to blame for the fatal error though. At worst the **** ink you use will clog nozzles and may even ruin the print head by clogging all the nozzles and causing only blank pages to be produced. BUT can you prove this to Epson in court?
My advice - bin the printer and replace it with one from a manufacturer who appears to give a damn about their products and customers as much as their fat pockets!!
Posted on May 27, 2008
  • 7 Answers
SOURCE: Epson 9800 Service Call Error 001002D
cleaning unit end of life
Posted on Dec 20, 2008
aicaxz
  • 511 Answers
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
Posted on May 30, 2009
aicaxz
  • 511 Answers
SOURCE: 2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
Reset waste ink counter. Find at indoreset.blogspot.com
Posted on Jun 03, 2009
Service error code 00010018 epson
Epson Stylus Pro 10000CF Error Codes
Code
00,010,018
Display
SERVICE CALL 00,010,018: INK SURFACE SENSOR (LC) OVERFLOW
Description
Surface of a liquid sensor defective or I/C valve solenoid defective it is (on condition).
Remedy
• I/C valve solenoid exchange • C362DRV board exchange • Surface of a liquid sensor exchanger
Sep 04, 2013 | Epson Stylus Pro 7880 InkJet Printer
Epson Stylus Pro 10000CF As soon as we start printing, the head travels then returns to its starting point, stops printing and displays :"out of paper" ???? Thanks in advance for any help.
Take a look at the service manual, I think you'll find a solution there..
http://www.file-upload.net/download-6754855/Epson_Stylus_pro_10000-10000CF.pdf.html
Mar 31, 2011 | Epson Stylus Pro 10000CF InkJet Printer
Is possible printing with eco solvent inks on epson stilys pro 10000cf, Thanks, Dragan
The 10000cf only takes Dye or Pigment type ink cartridges. Eco-solvent ink is a newer technology that is not compatible with this printer.
http://www.epson.com/cgi-bin/Store/jsp/Pro/InksAll.do?BV_UseBVCookie=yes
Mar 02, 2011 | Office Equipment & Supplies
Just purchased an Epson Stylus Pro 10000 Archival Ink. Nosel check looks good with solid lines, however prints are very light. Ran clean multiple times. Printer came with existing ink and I don't know if...
Old ink loses some of its intensity after about 8 months.
heat/light seems to destroy some of the depth in the ink's shade. i would be completely replacing the cartridges with fresh ones. Constant cleaning uses up so much ink and the casettes will need replacing too often. This raises the cost of your prints.
May 09, 2010 | Epson Stylus Pro 10000CF InkJet Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
My scanner
Open the scanner lid and slide the transportation lock back to the hw_translock_1.gif unlock position.
I will appreciate a Fixya rating if I were able to resolve your concern.
Oct 22, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Pro 10000CF InkJet Printer Logo
417 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
