Question about Alba Televison & Video
Alba karaoke system
Hi bought a second hand machine alba ca900 cdg
Going to take it to a party tonight and although I can make the red light come on and make the mic work - thats it. Dont think I have connected it to the tv correctly...do you have instructions for this machine.....
thanks
llian
5 Suggested Answers
SOURCE: FLECO CDG-11 KARAOKE
All signals go through the key change board. Electrolytic Capacitors (470 Mfd) on this board were bad - REPAIRED
Posted on Jan 10, 2008
SOURCE: can a xbox 360 play cdg discs like for a karaoke?
no it wont
Posted on Dec 23, 2008
SOURCE: magic (karaoke) mic sound delay problem when connected to HDTV
Ok..I found a workable solution. Essentially using my HDTV only for the lyrics(video output) and using a RCA to stereo mini plug cable to send the sound output to my amplifier that has a analog stereo input. Works like magic. No delay. It went from being unusable to WOW!
Posted on Aug 28, 2009
  • 5 Answers
SOURCE: i have a roadstar dvd/karaoke player it wont play
it is the machine because i have one and it plays them fine
Posted on Dec 17, 2009
SOURCE: karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Posted on Sep 27, 2010
I need help my machine is making a scratching noise when I put a CD in. And it will spin the CD for a few seconds and stops. It never readsvthecd or plays anything.
Hi, although you have cleaned the laser with a cd cleaner this may not have done any thing, if you can see the lens then get a bit of vodka on a cotton bud and gently roll it and move it in one swoop, do a few more times, it sounds like a cleaning or worse a lazy laser, if you got it 2nd hand then it could be either but first try cleaning with vodka if you can't get to the laser then see if you can take it out easy, the laser could be cheap enough to buy look on the back and get the model number search on flea-bay, oops, ebay for the model number followed buy laser, hope this helps try the cleaning first thou.
Jan 18, 2015 | The Singing Machine DVD/CDG Karaoke System...
Read error
Your reader is probably going bad. You can try cleaning it with one of those home CD player cleaner kits and that might work for you.
Aug 23, 2014 | Akai Karaoke Akai KS808 CDG Karaoke System...
When singing the mic has a delay
I had the same problem. How I fixed it I hooked the audio out (red and white) cables direct to my stereo. Seemed to stop the delay.
Feb 16, 2014 | Karaoke USA DV102 - Dv102 Dvd/cdg/mp3g...
GPX Karaoke Party Machine sound but no words
I think the backlight of your screen is out, which can be complicated. I think it is working but just not lighting up. I'll look this thing up and let you know more later. Please send me a make and model number when you can.
Mar 03, 2013 | GPX Karaoke Party Machine
Daughter received a GPX JM250S Karaoke Party Machine for Christmas and can not get the lyrics to display. I have a CD-G and it is on that setting, but no lyrics.
From the FAQ for this unit:
Make sure that you are in either CDG or AUX mode and then adjust the BRIGHT, CONTRAST, AND V-HOLD knobs, on the back of the unit, if needed
Dec 31, 2010 | Digital Products International Karaoke...
I have a karaoke vision machine, and the cd player does not work. Needs repair.The lights come on, but the cd does not turn. Would like to know how and where to get this fixed without costing an arm and a...
If the Red LED laser eye is coming on then thats good,, look to see if the cd spins at all,, maby just a bit,,
if it does spin a bit then try cleaning the eye,, if it dont spin at all its most likely the CD motor is bad..
If you can pinpoint the problem b4 you take it to the shop it will save you in trouble shooting fees.
Nov 28, 2009 | The Singing Machine DVD/CDG Karaoke System...
Cd door will only half open
Just bought a singing machine ism 1028 Karaoke Vision from Costco. It was a floor model and when We turned it on it only shows to flashing bars in the CD area. Won't play demo CD. Nothing else seems to come on either. I have tried to look for manual on line and am unable to find one. Not sure if i have hooked it up right or if I have all the parts. Help please.
Nov 13, 2009 | The Singing Machine DVD/CDG Karaoke System...
DVD drive cannot find cdg files
nero or power dvd sofware install your pc or driver file install
Jul 21, 2009 | Microsoft Windows Vista Ultimate Edition
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Televison & Video Logo
67 people viewed this question
Top Alba Televison & Video Experts
Rod
Rod
Robert Crombie
Robert Crombie
Level 1 Expert
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
