Question about Canon PIXMA iP1600 Printer
Ip1200 takes in paper on right only- tells me paper is out
As above...have fiddled about with cartridge- thinking they may have been put in wrong. The printer mangles the paper on the right and then the screen tells me there is no paper (even when there is a lot)
  • 4,041 Answers
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
My Epson Artisan 1430 ink cartridges not being recognized they are all brand new is there a fix for this
Are you using 79 cartridges? If so the only other thing it could be is you put them in the wrong slots. I have done this before. Also check the software on your computer an tell it you are installing new cartridges. An reinstall software, i have had to do that on my Lexmark so many times I quit useing it. The repair place told me once Windows has a habit of losing printer info an he had no idea why. It still acts up on my new laptop as well.
Jan 27, 2015 | Epson Office Equipment & Supplies
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
How do i align my printhead on canon iP1200
I assume you are using windows.
  1. Go to START, SETTINGS, PRINTERS, double click on the printer icon. Go to FILE, to PROPERTIES, then click on the printer SERVICES tab. Click on ALIGN the print cartridge button and follow instructions on the screen. hope this works
  2. Align the print cartridges Typically, you only align print cartridges after installing or replacing a cartridge. However, you may also need to align cartridges when:
    • Characters are improperly formed or are misaligned at the left margin.
    • Vertical, straight lines are wavy.
    From your printer:
    1. Load plain paper.
    2. Press the Menu button, and scroll to Align Cartridges.
    3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
    From your computer:
    2. Open the Canon Pixma IP 1200 Utility.
    3. From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears. alignprintcartridgesa.jpg alignmentpanther.jpg
    4. Click Continue to print the alignment page.
    5. On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
Apr 20, 2011 | Canon PIXMA iP1200 Photo Printer
My x4650 is not recognising when I refill the black 36XLA cartridge. Just keeps telling me it is empty. There is not a problem with the cartridge itself just the failure to recognise it has been refilled....
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. or take cartridge out and put back in to insure in securely.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Lexmark X4650 InkJet Printer
Black ink cartridge.
the printer only prints with all ink cartridge inside, back and color (use only original ink spares)
Dec 29, 2009 | Canon PIXMA iP1200 Photo Printer
Lexmark X5320 won't print acts like it's printing but paper is blamk, also tells me right ink is wrong( it is not)
Hello there,
The most common cause for printing blank pages is (1) Failure to remove the protective tape from the bottom of the cartridge. Even if you have removed the tape, there might be some residual tape left at the bottom of the cartridge. I would suggest you check out for this yellow or/and transparent blue tape at the bottom.Please remove it, if present. (2) If there is no tape left behind, then the next option is to clean the cartridge nozzles. I would suggest you go to Lexmark control program or Lexmark Solution Center and run the clean nozzle test. You should see solid dark lines on the print out. Repeat the process 2-3 times till you get a good output. (3) If all the above steps fails, don't worry.. we have one last thing to try... Remove the carts from the printer.. take a warm damp paper towel Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge. Repeat this process atleast two times and then put the carts back to the printer after 1 min (we need to allow the cart contacts to dry). Now you can install the cart to the printer and try printing. If you still have a problem with the cart, then I would suggest you try another cart as there should be something wrong with the cart that you have right now.
Merry Christmas!
Dec 21, 2008 | Lexmark Office Equipment & Supplies
HP LaserJet 1022 Error Message
I had exactky the same issue. The problem is not with the front door or the cartridge. I solved this as there was a very small paperjam. If you take out all the paper and shine a torch into the printer you may find a small piece of paper stuck on the sensor that is causing the problem
Aug 12, 2008 | HP LaserJet 1022n Printer
Canon pixma ip1200
also i lost cd set up printer pixma ip1200
looking here to solve and nobody give me answer
Nov 13, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP1600 Printer Logo
50 people viewed this question
old marine
old marine
