Question about Jensen A600HLX Car Audio Amplifier
My amp went into protect
Mt jesen A600HLX is stuck in protect, i dont kno whats wrong with it other then i was told i have blown a channel... i brought it to a company to fix it and they said they cant do anything without a schematic, ive searched evvveeerrryyyywhere and i couldnt find one, i like this amp alot even tho it might not be the best in the world, it was a strong amp. id hate tosee it go in the trash so could u please send me a schematic for my amp. or send the technician the schematic. or just tell me how to fix it if possible. thanks alot - tom
  • Thomas Fulop Jul 17, 2006
    alright well im not really an amp wizz or n e thing so... how can i do this? wats an emitor resistor and my multimeter has 7 different settings i can use to check ohms, i really dont kno whats anything looks like other than a resistor or a transistor. thanks - tom
    Scholar:
  • 148 Answers
See my solution for: http://www.fixya.com/problems-solutions/t115301,p424435/Eclipse-Car-Amplifiers.aspx And they shouldn't need a schematic unless they can't read the part numbers of the fried components.
Posted on Jul 16, 2006
Hi i have a small 2 channel mixer that i lent to a friend, i think he might have used an adapter set to a higher voltage and blown something? but i dont kno wat can it be fixed ?
How are we to even know what brand mixer you have... and have you tried it using your CORRECT adapter. Most mixers are pretty well protected against using wrong adapter. Many require an AC voltage input rather than DC and use of a DC adpater will not damage one unless the voltage is very high.
Sep 06, 2011 | Music
I have a 1200 watt G-Max sub amplifier and it just went into protect mode
Turn down the volume or power settings on it since its pulling too much power and shutting off for a few sconds to keep from blowing. Depending on the amp and speakers your using dont bridge the channels. If it won't come out of protect mode then unhook everything and just hook power, ground, and remote and wee what happens. If it comes on again and stays on then amp is blown.
Aug 11, 2010 | Jl Audio Car Audio & Video
Speakers not working--FM and CD player shows it is
dear friend-as you say the fuses are there to protect these devices,but sometimes things goes wrong.it appeares that the output channels on you stereo is blown,you will have to remove and have it checked.
Jul 22, 2009 | Hyundai Azera Cars & Trucks
Fuse blew on power now stuck in Protection Mode
Sounds like the out put stage of the amp is shorting, They are either 4 large transistors attached to an aluminium plate (heatsink) or one large chip with heatsink. also sounds as the driver stage went too when you switched it on the second time. If you know nothing of electronics I suggest you take it to an audio repair shop, as it is cheaper to repair than replace high power amplifiers.
Mar 29, 2009 | Audio Players & Recorders
Pioneer GM-D7400M power light keeps flashing?
ur rcas could b round the wrong way you might have a weak earth aswll
Mar 24, 2009 | Pioneer GM-D7400M Car Audio Amplifier
The amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Feb 10, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Protection light
double check the blue stereo input wire to amp is this a new amp if not speaker channels in amp might be blown
Nov 08, 2008 | Kicker KX120.2 Car Audio Amplifier
Huge static busts
Most if not all CB radios have a reverse protection diode soldered immediately right after the power connector. Its purpose is to provide a practical short if the wires are connected wrongly to a power source. This would cause the fuse to blow. The diode normally goes bad after a reversed polarity connection and therefore would need to be replaced. This diode is not in series with the B+ line but connected parallel to the power.
In some instances, other components would also fail: Power capacitors, Audio IC, TX finals and/or the switching/regulator IC.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 17, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Jensen A600HLX
These solid state amps have no user serviceable parts inside them as everything is soldered into place and your gonna need to know how to use a multimeter to trouble shoot the parts inside the amp on the printed circuit board. Sorry But without the proper training and the right tools you could cause more damage to the amp if you dont know what your doing. You cannot just open the unit and see whats bad. You must test each suspected bad part and replace it as needed. You should take the amp in to have a pro look at it, as there is no easy fix on these unless its an external fuse, and a fuse will very rarely blow all by itself. Good Luck
Jul 17, 2006 | Jensen A600HLX Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Jensen A600HLX Car Audio Amplifier Logo
321 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
