Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Problem for Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in...
Not enough water
By boatbound on Jun 08, 2006
I've changed the water lines, cleaned the fill valve and find nothing. I replaced the timer, and still very little water in tub! Checked the float, looks good. This model seems to fill by timer not float. It works great when I manually add water. Any ideas?
Best Solution
posted on Jun 08, 2006
Helpful)
dovi
Rank: Guru  Whirlpool Expert
Rating: 88%, 2494 votes
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!!
Check that the inlet valve get power. In case it does and no water
entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve.
In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt.
In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve.
The switch is an On/Off switch and you can check it easily by a multi-metr.
Good luck !!
Was this helpful?
Yes
No
Solution #2
posted on Apr 15, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
it is the pressure switch that controls the water level, it is also a switch connected to the motor,once the contact triggers so prematurely, your water level will not reach its designed level, or check the pressure.
Solution #3
posted on Nov 02, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Shut off the water valve to the dishwasher. Disconnect the water line at the dishwasher, place it into a bucket, and open the valve to check the water flow.
Solution #4
posted on Oct 29, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
go to miele UK & download manual for g670. has instructions on how to check and adjust water level
Popular Solutions for Whirlpool 24 in. GU1500XTLS
Questions and Unsolved Problems for Whirlpool 24 in. GU1500XTLS
Do you recommend Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher?
Answer
Answer
hello. I have a whirlpool gu1500xtlq2. the console is replaced and still doing the same thing. I... (More)
Answer
wont start. double dashes in display. checked switches and they are good. the rinse only light... (More)
Answer
Dishwasher does not come on. Light next to "normal" wash button is flashing and 2... (More)
Answer
I bought a brandnew whirlpool dishwasher now i have water at the bottom??? don't know how to drain
Answer
I have a Whirlpool dishwasher GU1500XTL53 that has a sensing problem. When I start in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool 24 in. GU1500XTLS...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
