Help.. How to Fix "Not Enough Server Storage" Error when Connecting to Computer on the Network
    Scholar:
  • 85 Answers
1) Open the registry editor on the machine you cannot connect to by clicking on Start, Run
2) Type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following entries
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Services
Lanmanserver
Parameters
4) In the right-hand portion of the Registry Editor look for a key called IRPStackSize
5) If the key exists, double-click on it and increase the decimal value to 15 and click OK. Close the Registry Editor, reboot the computer and try to connect to the network share. If you are still unable to connect follow the above steps again and increase the decimal number for IRPStackSize by 5 and try again. Continue to do this until the stack size is large enough to permit access. Personally, I had to increase the number to 25 before I could connect. The decimal range for the parameter is between 11 and 50.
6) If the IRPStackSize key DOES NOT exist in the right-hand column of the registry editor, then click on right-click in the blank area in the right-hand column and choose New
7) Then Click on D-Word under the Key column
8) In the Name of the new key, type the name IRPStackSize and press Enter. Type the name with the correct capitalization as shown above.
9) Now double-click on the IRPStackSize key and type 15 in the value data box and place a dot next to Decimal then click Ok.
10) Close the registry editor and reboot the computer. Try to access the network share again. If the same error appears follow the steps above to increase the value and reboot again. Continue this procedure until the problem is resolved. The decimal range for the parameter is between 11 and 50.
Posted on Oct 19, 2008
    Scholar:
  • 84 Answers
Follow these steps to check for problems on the machine you cannot access.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Services
Lanmanserver
Parameters
Posted on Oct 18, 2008
My ditto status led is off and I get error 301 when connecting my ditto.
Is the Network Server connected to something? Contact me if you require help.
Nov 05, 2013 | Dane Elec 1Tb Myditto 2-Bay Home Network...
Cannot connect to networked computer: Error - "not enough storage space to process this command"
Okay, first a bit of "techie" information. When you print you send a file to the "print spooler" on the system handling the printing. In your case, that is Workstation 2. That file can be quite large and if there are several sent at once it can take up a lot of room. Once the system finishes printing it then clears out that space on the hard drive. Second, because you also use that for a file storage it may be that a lot of files are stored on that system either permanently or temporarily. So....the answer is that you are probably temporarily running out of disk space.
The reason you IRPStackSize increase worked is that you set aside more space for that stack so the system could hand incoming data more easily ...which meant it could sometimes delay a disk write enough to avoid a printing error.
The solution is to either increase the hard drive capacity of the system or to move the printing or customer files to another system on the network.
Of course, I could be wrong about this....;>) but it's the first thing that occurred to me.
Jul 17, 2013 | Microsoft Windows 7 Professional for PC
Nas unreachable on network
Try connecting a USB mouse & keyboard DIRECTLY to the back of the server (plugging the monitor directly into it as well) then login directly instead of over the network. Repair may be possible if successful.
Dec 16, 2012 | LaCie Space 2 (301515EK) 1000 GB Network...
Server error 500
The adress of the server error is 00:D0:4B:8D:1C:50. Has anyone a solution? and The message was " Something wrong with the volume CNID BD"
Feb 29, 2012 | LaCie 2big Network (2-disk RAID) (301257U)...
The folders for the iomega storage drive no longer are displayed on my computer, and when opening up my network it shows the folders listed there but gives the error, "\\Network storage\public is not...
Make sure you are logged in as the Administrator of your computer. Power cycle (turn it off and back on) the device. If that doesn't fix the problem. Try factory resetting the unit (depress the reset button on the back of the unit for 4-5 seconds).
Dec 14, 2010 | Iomega 1TB Home Media Network Hard Drive...
Server conection timed out (80028e06)
Can you access the internet with a computer still?
Try rebooting the PS3 and the router. Reboot the router first, wait a few minutes, then reboot the PS3.
Which firmware version are you running?
Apr 03, 2010 | Sony Playstation 3 (PS3) Console
I have an error E06
Error E06 means corrupted firm ware,you can repair or update the firmware
Sep 27, 2009 | Buffalo Technology 2TB Linkstation Pro...
NAS 200 D 480 Gb , it doesn't boot: how to recover data from second partition
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Feb 18, 2008 | Iomega 200D (33060) 160 GB Network Storage...
Windows XP MSHOME Network problems
azerty, You applied this to the other computer too?
You may also come across this message and Event ID: 2011 in Event Viewer after you install Norton Antivirus for Windows (which seems to be the commonest reason why people see this message).
Jan 14, 2008 | Computers & Internet
Not enough server storage is available to process this command
Solution described here:
http://forums.techguy.org/networking/502748-solved-cannot-map-network-drive.html
Info on IRPStackSize here:
http://support.microsoft.com/kb/285089
Nov 15, 2007 | LaCie Computers & Internet
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
