No connectivity after.....
How to Troubleshoot and Solve Problem of Limited or
No Connectivity after installing Windows XP Service Pack 2
    Scholar:
  • 85 Answers
U have to configure networking setting again
cinfigure IP, workgroup etc
Posted on Oct 19, 2008
    Scholar:
  • 84 Answers
If you have installed Windows XP Service Pack 2 and are experiencing any of the following symptoms, this bug is affecting your system.
After installing Windows XP SP2, your network connection reports a problem with "Limited or No Connectivity"
You have trouble connecting to the Internet or your local area network after installing Windows XP Service Pack 2.
Your network connection gets stuck "Acquiring IP Address"
Posted on Oct 18, 2008
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
My windows xp service pack 2 shutdowns when i turn on fullscreen in youtube
check your display driver connectivity,, re install the vga driver and reboot your computer.
May 06, 2012 | Microsoft Windows Xp Home Edition Sp2...
Mtorola v3i ka software update kaise hoga
firstly you require the following on your system:-
  • 400MHz or higher processor speed
  • 256MB RAM or higher
  • Approximately 250MB of available hard disk space
  • Available USB port (USB 1.1 or higher)
  • Internet connectivity (Internet Explorer)
  • Windows XP (Service Pack 2) or Windows 2000 (Service Pack 4) or Windows Vista (either 32-bit or 64-bit) (Service Pack 1) or Windows 7 (either 32-bit or 64-bit)
NOTE:
During the software update, all third-party media, including but not limited to, music, pictures, ring tones, and screen savers, will be deleted. You will need to reload all third-party media after the software update. Third party applications and some custom settings CANNOT be automatically restored after the device has been updated. Please note that during the update, you will have the opportunity to save your personal data.
Please follow these steps below to download the Software Update
1. Connect your phone using the USB cable provided with the Motorola phone
2. download the update from the link provided below.
MOTOROLA UPDATE FOR MOTOROLA V3i
3. this will notify you if it contain a update for your Motorola model.
This will successfully update the software of your Motorola phone.
Dec 21, 2010 | Motorola Mobility Software Update
I cant install microsoft office 2007.my computer have window xp prefessional
You must have at least XP Service Pack 2 to install Office 2007. Is your XP Service Pack 1 or 2? If not you have to upgrade to Service Pack 2 to solve your problem.
Go to http://www.softwarepatch.com/windows/xpsp2.html to get Service Pack 2 for XP.
Nov 22, 2010 | Microsoft Office Standard 2007: Windows
Keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
Limited or no connectivity
hi
limited or no connectivity issue comes on a computer when modem and computer are not talking to each other in a proper manner .in this case the ip address of the computer turns to be 169.215......... which is a false ip first of all try to power cycle the complete system and while doing this flip the cables .once you have done that turn on your computer and check that it works or not .if not please try to trun off the firewall .even after doing this if it doesnot works then you need to hard reset the router and then you need to confgure it back again of the same problem comes please try to get back to me on fixya and i would love to solve your problem
Apr 23, 2010 | Microsoft Windows XP Home Edition
No network connection for windows xp
Hello kenji, hi, it would really help if you could add more information about the no connection problem, anyway there are several reason why you have no connection;
  1. Bad Lan card, or built in lan port,
  2. Lan card device driver not properly installed, check your driver CD.
  3. loose lan cable. check using a lan cable tester device.
  4. bad router or router setup.
  5. bad dsl or modem setup.
  6. bad telephone connection. check also telephone cable.
  7. no internet service, call your ISP.
  8. if you are using a wireless lan card, check the device.
  9. bad Operating system installation.
  10. check your connectivity setup, is it enabled?
Go through each from one to ten, see which one is the fault.
Jan 14, 2010 | Acer Computers & Internet
My PC is not installing XP service pack 2
You'll need to upgrade your RAM, minimum requirements for windows xp is 512MB.
for the best price on ram go to http://www.pricewatch.com
i would recommend at least going to 1 or more gig.
Mark
Mar 27, 2009 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Device Manager is not showing
- service pack 3 has been released , try to install it.
Jul 07, 2008 | Microsoft Windows XP Professional With...
Cant connect mobile phone to ym
just re install u r mobile connectivity software....
1 st remove it and then install it again..
im 100% sure it will solve u r prob man
ok by
best regards & best of luck..
Oct 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
153 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
