Boot volume err
Troubleshooting the Unmountable Boot VolumeError Message in Windows XP
    Scholar:
  • 84 Answers
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Posted on Oct 18, 2008
Unmountable boot volume
get a copy of hirens and run HDD regenerator I think you have some bad sectors and a corrupted windows.
Feb 03, 2013 | Dell Latitude D410 Notebook
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Unmountable boot volume hp pavilion ze4400
Recommend entering Windows XP CD, and entering R once the CD Boots up, and enters installation mode.
This will bring you into the Admin panel, enter password, and than enter chkdsk c: -f Once this is completed eject CD, and than restart XP.
Jun 30, 2009 | HP Pavilion ze2000 Notebook
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
I have the same issue and my aspire is idle for last 4 years...
Jan 12, 2009 | HP Compaq nx7010 Notebook
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Computers & Internet Logo
372 people viewed this question
David Payne
David Payne
