Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter thermostat set' n save II
I don't have the model # and according to the fur. it was installed 4/99. Anyway moved in here this summer and how winter is moving in - I put new filter in fur. and went to program the thermostat to check it out and no go - I can switch to fan and it runs fine - I installed 2 new aa batt. and it go's to the 12:00 72 on screen I try to press hour and the screen go's blank - so I purchased new aa batt. and again and still same deal - my panel;
top - switch with: heat off ac (set to heat) fan: auto fan (set to auto)
middle - hour, min, day, usage review
bottom - program, hold temp, return
cactus bob
  • 267 Answers
SOURCE: Hunter Fan Model 44260 eats batteries
you have to replace the thermostat . problems like this are common with latest electronic thermostats from china . most are going bad in less than 4 years . it so bad ,i am telling anyone who asks , to please keep there old regular thermostat , or if you have one of the old electronic ones (made over 10 years ago) hold on to it , it will last forever.... somehow when we moved the factory to china they forgot how to make thermostats that last ........ if you plan to rate this answer , please rate it 3 or 4 stars . this will help me stay in the paid answer department
Posted on Apr 01, 2009
SOURCE: Programmable Hunter Thermostat
Our progammable thermostat continues to flash
Posted on Mar 25, 2008
SOURCE: Instruction Manual for Model 44860 Hunter Thermostat
Well, I consulted with Randell (my 12 year old grandson) - he assisted me in finding the solution in converting cooling to heating on the touch pad. Jameson (the 4 year old grandson) looked on, wanted to help Pa-Pa - but, we could only listen to his demands to help.
I still need an instruction manual - can you advise me how to obtain a replacement (or print one from the internet)?
Your response will be greatly appreciated.
Regards,
J. Alan Overton, Sr.
Posted on Nov 19, 2008
SOURCE: Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Posted on Apr 07, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
Hunter model 4409. How can I reset?
Reset hunter model 4409 - Fixya
www.fixya.com/support/t26079594-reset_hunter_model_4409
34 mins ago - reset hunter model 4409 - Hunter Set and Save Programmable question. ... Clicking this will make more experts see the question and we will ...
Controller Frequently Asked Questions ' Hunter Industries
www.hunterindustries.com/homeowners/.../controllers
Hunter IndustriesWhen the station or stations finish watering the controller will go back to ... How do I reset my Hunter controller · How do I address the Wireless Solar Sync sensor ...
CodeLink®, Steering Angle Sensor Reset Tool, Wheel ...
www.hunter.com/alignment-systems/codelink
Hunter Engineering Company's CodeLink® steering angle sensor reset tool plugs into a vehicle's OBD-II port.
Feb 03, 2016 | Heating & Cooling
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Trying to put a new thermostat on my furness , my furness is a GSC90904CXA the new thermostat is a Hunter 44110. I need help hooking up the thermostat.
I'm not familiar with that model # but most furnaces are similar. R goes to R (usually the red wire). If you don't have a seperate heat source, like a boiler, the wire needs to connect to both Rc & Rh. Stats usually come with a jumper in place. Then W to W (usually white), G to G (usually green) and Y to Y (usually yellow or blue). Before you make any connections, TURN OFF YOUR FURNACE. If you don't, you'll probably blow the fuse on the control board, or worse yet, blow your transformer.
Oct 16, 2008 | Goodman Heating & Cooling
Hunter Fan Company 5 + 2 thermostat #44110 Set and Save/Energy Star
i would say normal, between my family have 3 different hunter models, and they all do it.
Jul 04, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermostat problem
I can't see a thermostat for the reference given (30124). According to my listings that's an air conditioner.
I do have the manuals for Hunter - Just click HERE for a list to the PDF documents you can download and print off.
Thanks for using Fixya, If it has solved your problem, please rate as such. thank you.
Jul 01, 2008 | Hunter 30124 Air Conditioner
Hunter therm
try to reset. if doesn't work properly, repalce the thermostat.
Jun 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,357 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
