Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
No internet connection via DWL-G710
Hi, i've such a problem: there is low range of wireless network signal in my building so i've bought D-Link DWL-G710 range extender. now i've very good range but there is no internet connection via extender. when extender is disconnected i can connect my computer to internet but speed is very low because of lower range.
any ideas??
thanks
/jt
  • jimmypitmane Oct 19, 2008
    Same issue as mentioned, cannot find help anywhere!
Hi, the problem is that no encryption is set at both devices. there are neither MAC filter nor network password. default gateway is the same. and no one can find solution - even service :(
Posted on Dec 20, 2008
Your extender may not be able to talk to the router. Make sure you have set default gateway in extender to IP of the router. Turn off encryption first. Check the router if extender shows up in active client list or active mac address list.
I bought the DWL G710 range exender hoping to boast range for ipad use, so can't use CD and tried the internet address given in the manual but it does not connect. Apart from the connection problem that...
Connect a LAN cable from the D-Link to your computer's LANport, open a browser and enter the D-Link's configuration URL. OR open thebrowser on your laptop and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings .
Feb 27, 2011 | D-Link AirPlus G Wireless Range Extender...
Trouble logging into a D-Link DWL-G710 Wireless
Let me try to get the info straight:
Your computers IP address (manually configured): 192.168.1.4
D-Link Range Extender IP: 192.168.0.30
If this is correct, you will need to change your IP to something like:
192.168.0.X (make sure it's not in use on your network already)
otherwise you will not be able to connect to it with your comptuer.
Apr 03, 2010 | D-Link AirPlus G Wireless Range Extender...
Different router and extender signals
you are seeing your neighbours wireless as well. hook up to the one that is your router/provider
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL-G710
check the dial-up configuration settings. via the admin web page for that DWL-710 gateway
Jun 27, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
LAN problems with the router
Are you using the correct cable type. If it is a CAT5 type cable it could be you are using a patch cable rather than a straight through type or vise versa.
May 23, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
DWL-G710
Move the repeater directly next to the router, connect to the repeater with a laptop/desktop and enter the configuration utility, see if you are even able to establish a "signal" status. If not, you may have a defective product or extreme amounts of emi.
May 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
791 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
