PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
Bios problem
By victor955 on Oct 18, 2008
Power On Self Test (POST) Beep Codes and Bios Error Messages
Best Solution
posted on Oct 18, 2008
Very Helpful)
rush2aaman
Rank: Guru
Rating: 85%, 58 votes
Standard Original IBM POST Error Codes1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
PCHELL.COM Newsletter
If you would have read my E-book on Internet Security, you may not have ended up in PCHELL. Join the PCHELL.com mailing list and receive your free E-book now.
Name:
Email:
Tools for Removing Spyware, Adware, and Malware
PC HELL
Other Pages
Spyware/Adware Removal Help
MSBlast.exe Worm Removal
Welchia (Dllhost.exe and SVCHost.exe) Worm Removal
Uninstall McAfee Instructions
Uninstall Norton Instructions
Uninstall Avast Instructions
Uninstall AVG Instructions
Uninstall Antivir Instructions
How to Manually Run the Microsoft Malicious Software Removal Tool
Bloodhound.Exploit.6 Virus Removal
MyDoom Virus Removal
MiMail.C Virus Removal
Swen Worm Virus Removal
SoBig.F Worm Removal
Dumaru Virus Removal
BugBear.B Worm Removal
SoBig.E Worm Removal
Pop Up Ad Removal Info
KAK Worm Removal
MiMail.A Worm Removal
W95.MTX Virus Removal
Snow White Virus Removal
BadTrans Trojan Removal
Wininit Virus (Bymer Trojan)
Happy99 Worm Removal
VBS Netlog Worm Removal
Pretty Park Worm Removal
Sasser Worm Virus Removal
Backdoor SDBot.H Trojan Removal
VBS.Loveletter Help
Computer Security Information
Back Orifice Information
PC HELL Main Page
IBM POST Diagnostic Code Descriptions
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Color/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Color/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
 1 Short Beep One beep is good! Everything is ok, that is if you see things on the screen. If you don't see anything, check your monitor and video card first. Is everything connected? If they seem fine, your motherboard has some bad chips on it. First reset the SIMM's and reboot. If it does the same thing, one of the memory chips on the motherboard are bad, and you most likely need to get another motherboard since these chips are soldered on.
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above.
4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
5 Short Beeps Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
6 Short Beeps The chip on your motherboard that controls your keyboard (A20 gate) isn't working. First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
7 Short Beeps Your CPU broke overnight. Its no good. Either replace the CPU, or buy another motherboard.
8 Short Beeps Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
9 Short Beeps Your BIOS is bad. Reseat or Replace the BIOS.
10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard.
11 Short Beeps Your problem is in the Cache Memory chips on the motherboard. Reseat or Replace these chips.
1 Long, 3 Short Beeps You've probably just added memory to the motherboard since this is a conventional or extended memory failure. Generally this is caused by a memory chip that is not seated properly. Reseat the memory chips.
1 Long, 8 Short Beeps Display / retrace test failed. Reseat the video card.
Was this helpful?
Yes
No
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
what is the price for microsoft notebook receiver v2.0
Answer
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send Machinery until you... (More)
Answer
We are planning to use our Dell Dimension 3000 for security alone. A friend told us to get a... (More)
Answer
got a compaq desk top model SR2177CL went in and adj. hibernation settings now the screen keeps... (More)
Answer
I have a CE-3700 that someone gave me. It worked fine the first day I had it and now if I press any... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Desktops:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
