Question about BenQ FP71G 17" LCD Monitor
Benq lcd c5707 transistor issues
I have a Benq flatscreen lcd monitor that has a back light issue. I am not able to llocally source the c5707 transistors and have substituted the transistor pair that are blown with similar V and current NPN's. Now the monitor turns on for one second then the backlight goes out.
Will the correct transistors fix this or could there be another fault?
  • martindaniel Oct 23, 2008
    Ok thanks, I gathered that. In my case the capacitors between the transistors (the o.22uF caps) both had dry joints and were loose. I replaced these and resoldered the transformers. I have tried other similar NPN transistors but the result is the same. Turns off after one second. I will just have to wait for the correct transistors to arrive in the mail.
    However, I replaced the transistors with common MEJ3055 transistors from Jaycar on a 15 inch dell (aka benq) and it works fine, but these do not have the same result in the benq 17 inch monitor which turns off after one second, so again, I think I just need to wait.
  • emmcay_elect Jan 21, 2009
    Hello sir, i have also the same problem of c5707 shorted. and i tried tip3055 same trouble after a second display disappear. Is there any parts involve to be replace? BENQ model Q7C3.thank you.
You need transistors with hfe greater than 300. They are harder to get and you should use the producter`s original transistors 2sa5707.
Posted on Dec 15, 2009
  • 105 Answers
These transistors short due to deterioriated solder joints on the leads of the transformers. Unless you resolder the connections you will have shorted transistors again.
Monitor Mike
Posted on Oct 22, 2008
BenQ Q24W5 LCD monitor circuit diagram
HI.............
Repairing BenQ 17′ LCD Monitor
I came across a common fault problem in BenQ 17′ LCD Monitor. The problem is have power but no display. Once you has opened the LCD cover, check the pico fuse for open circuit (very common), the push pull transistors C5707 for short circuit and the Buck royer circuit p-channel fet FQU11P06 also for short circuit too. For your information, if you can't get the FQU11p06 you can always use FU9024N as a replacement. Resolder all the high voltage transformer pins and replace the components above and I'm sure you will bring back the life of this BenQ 17′ LCD Monitor.
You may go to this fairchild semiconductor website to download the spec of the FQU11P06 P-channel FET.
http://www.fairchildsemi.com/ds/FQ/FQU11P06.pdf
GOOD LUCK.............
Sep 23, 2011 | Computers & Internet
Repair BenQ Q24W5 monitor
HIIIIIIIII...................
Benq T905 Monitor's green light turns on and then off
Check for blown MOSFET IRFU9024N and transistors C5707/5706, and fuse in the inverter circuits section. Also look for bad caps with bulging top/seal. See some pictures of failed Dell monitors (BenQ made alot of monitors for Dell), http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | BenQ T905 (Black, Silver) 19 inch LCD...
Benq t7q3
look at the 3 amp. fuse on the mainboard! By the way, you can buy very cheap USB light, wich are working with a small lighttube. Use the transistors of their generator!
Mar 09, 2009 | BenQ T705 17" LCD Monitor
BenQ 17inc LCD Monitor
change c5707 transistors ...all 4 of them plus fuse
Feb 10, 2009 | BenQ FP731 - 17" LCD Monitor
Back light goes out after start up
You have BenQ syndrome.
Sounds strange I know, but the power supply in your monitor is a BenQ manufactured part.
The problem is in the inverter section of the power/inverter board.
There are 4 small transistors (marked C5707) 1 or possibly 2 of these will have shorted out. Using a multimeter find the shorted one, and replace both of that pair, even if only one is shorted out.
There could also be other underlying issues as well that caused the transistor to fail in the first place.
Mar 28, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP731 17" LCD Monitor Problem
Connect it to another device, if you get the same result the backlight is bad! These can be replaced, but can be costly!
Nov 14, 2007 | BenQ FP731 17" LCD Monitor
Dell E172FPb 17" LCD Monitor Problem
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Oct 27, 2007 | Dell E153FP 15" LCD Monitor
BenQ FP731 Screen briefly displays then turns off
hi. i had the same problem and fixed it. the problem are the 4 transistors (C5707) one of more are shorted (Q739,Q740 and Q759, Q760). Also the fuse PF751 (3a) has to be replaced in most cases. In my case i replaced the fuse and 1 transistor (C5707)
Dec 06, 2006 | BenQ FP731 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
2,217 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
