Question about Nikon Coolpix 3700 Digital Camera
Connecting camera to pc
Every time I switch the camera on after attaching the usb cable, it crashes the computer. I've tried a new cable & on other pcs but it still happens.
  • 53 Answers
My best guess would be a dead short in the usb connector internal in the camera. i would ask myself if it would be cost effective to repair or replace the camera.
Posted on Jun 08, 2006
SOURCE:
When I switch on to download photos the camera lense slightly comes out and there is also no beep noise that normally follows, it is not letting me download?
Even if the USB cable is connected perfectly to the camera and PC it still is not sure everything in the cable and both connectors is 100%. Or even the drivers in the computer can be corrupted.
Start with another cable, and if possible try to connect another camera to the compeer, to check the computer acts normal to that.
Always try to isolate a problem to one thing.
For the time being, you perhaps could place the memory card in an external card reader connected to the computer, to put the pictures on your computer that way?
Jan 29, 2014 | FUJIFILM FinePix S1800 Digital Camera
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
Where do i insert a memory card from camera to transfer pix to desktop
If you have a builtin card reader else you can use usb cable or buy a card reader which is cheap about £1.
Jul 07, 2011 | Computers & Internet
Connection of camera to computer
This can cause by a bad usb cable that you're using to connect the camera to the computer, so better try to use another USB cable and also connect the camera to another USB port on your computer so we can check if the USB port is bad or not...
May 15, 2009 | Canon PowerShot SD1000 Digital Camera
USB connection with the camera causes computer to crash.
Try using a different USB cable. The connections between cameras and computers usually are problematic. A card reader will allow you to download the pictures from the SD card, without problems and saving your camera's battery power supply
May 04, 2009 | Canon PowerShot A560 Digital Camera
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Switches off when USB connected to PC
Try another usb connector on the computer.
the camera or usb connector may be damaged.
you can always get a cheap memory card reader for your computer as a fix.
Mar 10, 2008 | Olympus FE-230 Digital Camera
Nikon Coolpix 3700 Digital Camera Logo
32 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
