Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
DLINK DWL-2000AP config
Hi. I am trying to access the admin page of this unit. It is connected directly to the computer and the IP config on the computer is 192.168.0.51. SM is 255.255.255.0 and GW is 192.168.0.1. When I do an ipconfig from the CMD the response is the 192.168.0.50. But, when I try to access the admin page from the IE browser using 192.168.0.50 I get a time out nd not the admin page. HELP...
Thank you
  • Carl Navarro
    Carl Navarro May 11, 2010
    The fine print of the connection is that you use a crossover cable if you are connecting directly to the AP. (huh? No auto sense?) You could just use your computer, a switch and the AP and try that in lieu of a crossover.
    If that fails, the reset button is probably your next step.
    Dlink has some neat troubleshooting tools online at http://support.dlink.com/products/revisi...
    Just find your label and click on it and it opens up a web page of FAQ's, and downloads.
  • D-Link Master
  • 787 Answers
You should be entering the address of the gateway.
http://192.168.0.1
Posted on Oct 18, 2008
  • John Hong
    John Hong Oct 19, 2008
    My bad, late at night, just answered a router question and it did not click that this was a AP, not your gateway.
    192.168.0.50 is the default address for this unit unless it has been changed. Since you say you are getting a response in cmd ( I assume you pinged it) it probably hasn't changed.
    In other words you should be getting the admin page with that IP, since your are not I suggest rebooting the unit if you have not already done so. If you have then try using the reset button (hold for 5 secs) to set it back to factory default. If that does not work you are probably looking at a bad unit.
    Another possibility - check the range of addresses being handed out by your gateway (I assume it is also your dhcp server), make sure 192.168.0.50 is NOT part of that range. If it is, a computer on the network may have that IP address also. Note that the AP's IP address is static so it is not asking your DHCP server for one. Your problem could be an IP conflict.
Cannot connect to Dlink DAP-1513 at 192.168.0.50. Unit is plugged into home network router.
Plug a computer into the D-Link.
Under Windows 7, click the "Start" button.
Into the search-box, type 'cmd' and press ENTER.
Type 'ipconfig /all'.
Look for the IP-address of the "gateway" (or the "DHCP-server").
Type that IP-address into your web-browser.
Feb 10, 2014 | D-Link AirPlus Xtreme G DWL-2000AP...
TALKING ABOUT THE ACCESSING THE IP ADDRESS ON THE DWL-2000A,I DON'T THINK I UNDERSTAND THE SOLUTION TO THE CONNECTION BECOS THERE IS ONLY ONE LAN PORT ON THE AP WHICH ONE CAN CONNECT TO THE MODEM. SO IF...
To connect the AP directly to your PC you sould need a "crossed" LAN cable.
On you PC you need to set a IP Address of the same subnet of DWL-2000AP (defaul IP is 192.168.0.50) like 192.168.0.xxx
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and select "Internet Protocol (TCP/IP)", click properties, now set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Confim clicking OK OK OK...
Now you can access you devices tipyng http://192.168.0.50 on your prefered browser. Default login is "admin" as username and empty password.
Let me upate.
Sep 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
I cant istall dlink dwl 2100 acess point.prescribed site is not opening
be sure to check every point on this TIP
to connect to "prescribed site" (I assume the default router IP address 192.168.0.1) you must be on same subnet and connect using a cable to router.
Consult Quick install Guide
or follow user manual Page !0 instructions:
First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
Open your web browser program such as Internet Explorer. Type the IP address of the DWL-2100AP in the address field (http://192.168.0.50) and press Enter. Make sure that the IP addresses of the
DWL-2100AP and your computer are in the same subnet.
If you need help in the matter let me know and I'll send you instructions
Jan 24, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Assigning an IP address to a computer
if you comptuer is runnin on winxp you can try the steps on this link. click here.
Jul 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Change the ip address
If your AP password erros, you can't enter the setup page of your AP in you browser. Do hard reset. Press little button behind your AP about 30 seconds. Will reset your AP to factory default, IP 192.168.0.50 subnet 255.255.255.0 user name: admin password: leave it blank.
May 24, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Can't connect to configure password through web address 192.168.0.50
Here is what you can do. You need to access the setup page of your Dlink Access Point.
1. connect a computer directly to the access point (via ethernet). Then assign an IP address on the computer (IP: 192.168.0.10 Subnet Mask 255.255.255.0 DG: 192.168.0.1 ). It is necessary for you to assign an IP address because your access point does not have the ability to assign an IP address to the a computer, its is not like a router.
2. After you assigned an IP address, you can now access the Dlink Access point's setup page. To do that open your browser in the address bar type http://192.168.0.50 (this is the address of your access piont) and it will ask you to put a username and password. Just type admin for both username and password field. And it will take you to the setup page of the access point.
3. To enable a wireless security, just click the tab on the left hand side that says Advanced, it will populate the options under Advanced and select security. On the main screen you will now have an option for security modem, you can select wpa-psk, then on the Key box you can type any password that you want (8-63 characters). Then click update there at the bottom of the page. If you also want to change the name that the Access point is broadcasting you can go to the on the left hand side that says Wireless and put any name that you want on the box that says SSID. After that click updat button again.
4. Now after updating the settings, You can reconnect to the network. And this time you will now be asked for the network key. Just type your network key. That's it.
Just reply to this post in case that you need more help.
May 20, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Please help! d-link airplus xg dwl 2100AP
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work.
Hope this Helps
Tech
CCNA, CCSP, MCSA
Mar 23, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
543 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
