Question about LG Studioworks 900B 19" CRT Monitor
Monitor screen dark & takes a while to power up
The machine takes a 5-10 seconds to display an image once powered on after shut off at main switch.When it does stablise the screen is dull and bearly visable even if the brightness & contrast is turned up. Tried adjusting the flyback voltage for sceen brightness but that distorts the image.chech=ked for dry joints & visual inspection for leaky / swollen caps .
  • Piyal Perera
    Piyal Perera May 11, 2010
    Was the tube and the circuit board covered with dust?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Could you post make and model?
Posted on Sep 22, 2017
2 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: monitor repair
the neck board of the monitor needs tube replace it is corroded with carbon if you cannot get a replacementbuy a new monitor.but also check the flyback also it could be faulty replace it check www.dalbani.com for your monitor parts or repairworld.com,good luck.
Posted on Apr 26, 2007
St2410b no display
When the following conditions, namely the need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/dell-n26397-lcd-inverter-p-5754.html
Aug 22, 2013 | Dell E173FP 17" LCD Flat Panel Monitor
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
My screen is all black with the words no database what does this mean ?
When the following symptoms, the need for LCD inverter with a: No image on the screen, but the power light stays on
Aug 04, 2013 | Sceptre Computers & Internet
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
Jun 07, 2013 | Computers & Internet
Monitor wont display image. On power up the image flashes on for a second and then goes dark.
Sounds like an inverter problem, but before taking into a TV repair shop, check the connection at the power input socket, also try a different power lead
Jul 17, 2011 | ViewSonic VP2365WB 23 inch Monitor
Screen keeps t going blank but still have power
It may be the internal backlight that is failing. When the display has failed but still has power, take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 24, 2011 | Xerox XG-91D 19" LCD Monitor
Shuts off to a dark grey, turn VS power off>baon to display image
You may have failing DC filter caps in the power supply just like Viewsonic monitors you can see in my albums, you is about the same as 2235.
If you are not going to DIY you will be better off putting the money toward new monitor, estimate repair up to $100.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 24, 2010 | ViewSonic VX2035WM LCD Monitor
Samsung LNS2641D 26-Inch LCD HDTV lost its picture
I'm afraid that while their intention was good, that most the posted solutions miss the mark. Let me guide you thru the diagnosis and possible cure. This is detailed and lengthy, since these points appear often in LCD TV/Monitor repair. You may wish to warm up your soldering iron and skip to Step (11) for the repair procedure.
(1) We know that much of the Main Power Supply is working since many of the audio, video and digital processing sections appear to be working (sound, remote control, tuner, and video out).
(2) We know that the Backlight Inverter is working. Even thought the screen appears to be dark, light from the backlight tubes can clearly be observed. Further, even thought the screen is dark, you *can* observe a small amount of the backlight thru the screen.
(3) When working on LCD TVs and Monitors, the typical problem is backlight failure. (Fortunately this is NOT the case here.) Backlight failure is most often due to Backlight Inverter failure, or Main Power Supply failure. Rarely do the bulbs fail outright (although occasionally thru abuse a CCFL tube is cracked or shattered).
(4) The typical failure mechanism on LCD TV/Monitors that have many in-service hours on them is CCFL tube aging. As the CCFL tubes get older they require increasingly higher voltages to maintain the proper regulated current thru them which in turn creates the correct light output. The higher voltage is often beyond the design limit of the Backlight Inverter leading to component failure. Typically discharge breakdown arcing on the output transformers (that drive the CCFL lamps), or drive transistor failure in the Backlight Inverter power supply. Alternatively, the Main Power Supply may fail. Typically the Main Power Supply supplies +12V, or +15V, or a higher voltage (+24V?) to the Backlight Inverter subsystem. Once again, as the lamps age, more current is drawn, and if the Backlight Inverter doesn't fail outright, it draws excessive current from the Main Power Supply leading to either Main Power Supply failure. Alternatively, the Main Power Supply protects itself by shutting down once the excessive current is detected. This can often be seen as "monitor cycling" where by a LCD Monitor will initially power up, but subsequently cycles every few seconds as the Backlight Inverter draws too much current causing the Main Power Supply to shut down. Then, after a brief recovery period, the cycle repeats.
(5) Another failure mechanism, that should not be overlooked, is Electrolytic Capacitor failure. The Internet has many sites documenting either manufacturing defects in Electrolytic Capacitors used in any of the subsystems (Backlight Inverter, Main Power Supply, Digital Signal Processor, etc.). However, more often than not, Capacitor failure is due to component stress-due to the high ripple currents present in inadequately designed switching power supply subsystems. Additionally, many inferior Electrolytic Capacitors of Chinese origin are inadequately designed-they lack trace chemicals in the Electrolyte necessary to assure long service life.
(6) If you suspect any of the mechanisms described which cause an absence of CCFL backlight, you can often use a small pocket flashlight, and observe the screen image *is* in fact present on the LCD panel, but in the absence of sufficient backlight, you mistakenly believed the LCD panel to be dead.
(7) This is not the case here. We can clearly see that the CCFL backlight *is* lit, but we also do *not* observe any image on the LCD panel, even with an external flashlight.
(8) Thru this diagnosis of exclusion we assume that either the LCD panel itself is defective, or that the LCD panel is not receiving the correct drive signals from the Digital Signal Processor subsystem.
(9) A cursory examination reveals that the Digital Signal Processor board is producing output activity, which-even if malfunctioning-would likely produce some sort of LCD display activity.
(10) The LCD panel is totally dark (backlight is on, but no image at all). This failure is so absolute, it leads one to suspect power related problems as opposed to logic or drive problems.
Nov 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Jul 28, 2008 | ViewSonic VA702b 17" LCD Monitor
When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
Jan 30, 2008 | LG L1915S 19" LCD Monitor
LG Studioworks 900B 19" CRT Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
