Model is Goodmans LD1503 15" LCD Colour TV. No picture but can hear sound. You briefly get a picture when you switch the set on or change channels but then it disappears again. Have tried switching off at mains and leaving it overnight but still no change
  • 3130 Answers
SOURCE: toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Posted on Jun 29, 2006
  • 110 Answers
SOURCE: Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Posted on Feb 17, 2008
SOURCE: Insignia NS-LCD32FS strange behaviour
Sometimes this can be fixed by removing the power plug from the wall and either allowing it to sit or grounding the power leads together (UNPLUGGED) to remove and residual charge. I know it sounds nuts but it has worked for me on three separate electronic devices
Posted on Apr 11, 2008
  • 1689 Answers
SOURCE: No Signal through on my main TV input.
This may be the tuner or IF module that is failing. It may also be a voltage supply fault to these modules. It is impossible to accurately speculate without actualy troubleshooting the set.
Jerry G.
Posted on Apr 19, 2008
  • 417 Answers
SOURCE: my goodmans lcd tv has
Needs Repair Mate - the problem Its In The Main Board
Posted on Jul 15, 2008
I have a Goodmans 19"
Sep 12, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Picture no sound
Reset the tv back to factory setting,by unplug,repluging it an hour later.Go in ur tv AUDIO setting reset it,now it back to factory setting,Should work,not than the tv Tuner board recieve the broscast signal boad is have problem must br replaced.
Jun 02, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Sound but no picture on my goodmans gtvl32w17hdf lcd tv
Nov 21, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
When i turn my goodmans plasma tv in and switch it on i just get a faint blank screen and the red power light dosen't come on can you help me with this please thankyou
Hi this is abhishek and welcome to fixya,
it is the problem of colour wheel see whether any burnt resistors it may be also a cause if its not its definitely colour wheel problem..better to change it or fix it
thank u..........
May 03, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Ps2 to goodmans tv
Which version of the PS2 do you have (NTSC or PAL)?
And same question about the TV?
Dec 30, 2007 | Sony PlayStation 2 Slimline Console
Goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Dec 30, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
