Question about Whirlpool Calypso GVW9959K Top Load Washer
What does the error code LD mean? The unit functions well most of the time..except sometimes I'll get an LD error.
  • Anonymous Dec 01, 2008
    I get the ld error sometimes... and now it has given it to me and won't run a full cycle. Even if empty. It just stops 1/2 way and says "ld"
  • Anonymous Dec 08, 2008
    ld keeps coming up half way through cycle and won't complete cycle.
  • 905 Answers
It is taking to Long to Drain
so the pump or hose is clogged
Posted on Oct 18, 2008
  • jason Oct 18, 2008
    even the bottom of tank hose can be clogging
Again and again got a error of sc329 .......how to fix
this error code came from the LD unit which means the seconder LD is not synchronized on the machine but try to clean the mirror if it came agin the replace the LD board
Aug 14, 2015 | Gestetner DSm745 Black and White Copier
LD WHAT DOES THAT MEAN
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 15, 2010 | Washing Machines
I have a ld error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Have Kenmore elite oasis that is coming with Ld code then F32 which means machine is taking too long to drain. The pump runs fine pumps all the water out. The hose is not clogged water drains freely....
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
LD = LONG DRAIN
Aug 02, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does it mean when LD shows in the display on my washer?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Apr 03, 2009 | Kenmore Elite 20972
Shoots out code U1, freezes up after about 1 hour
Uh oh it's time for laser work...accordianman
Feb 28, 2008 | Televison & Video
Whirlpool Calypso GVW9959K Top Load Washer Logo
259 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
