Bose Companion 5 Producing Unstable Sound
I have brand new BOSE Companion 5
I would like, why when I'm playing music with intensive bass, after 2-3 songs (around 15 minutes) the sounds become unstable, like the volume is being raised and decreased simultaneous and it really make my hearing dizzy.
But after I paused for 5 minutes - 10 minutes, it normal again, I think it's like being overheat/overused, but I think I didn't.
Comparing with my previous MAKO Razer 2.1 Speaker, to be honest that speakeris tougher at bass intensive.
Any of you encountered the same problem with my BOSE Companion 5 ?
Thank you for your kind attention.
  • 2 more comments
  • Andy Chandra
    Andy Chandra Oct 22, 2008
    Thanks for trying, but it's not about the volume, because the volume still at there (around 80%)
  • Aman225 Nov 15, 2008
    I have the same exact problem. I've had my companion 5 speakers for about 2 months now and I'm having this issue. I have the bass all the way up. I guess I'll try lowering the bass.
  • Anonymous Apr 13, 2009
    I have the same problem as you describe, so it must be a common issue. The manual does mention that the volume may drop to prevent overheating, the the fluctuation is irritating at times.
  • Andy Chandra
    Andy Chandra Jan 08, 2010
    Hi... I'm the owner of BOSE Companion 5, below is the result:
    I returned My BOSE Companion 5 to the store and they exchanged with new one, and now running smoothly without problem. The store manager says the old one has problem with the logic board so they need to return to the factory. Thx God I have an excellent computer speaker...
I am also facing same issue and I will sticking a PC fan onto it. Simple 0.5$ solution!
Posted on Nov 10, 2009
Had it again today. Disconnected and reconnected the power cable and it was gone! Not sure how it works. Does it sense the the temperature of the amp? Probably not. More likely to be some kind of timer that senses how long it has been running at a certain load. Disconnecting the power probably resets it.
Posted on May 15, 2009
  • 728 Answers
The intensive bass is making the speaker shake very much and that could have caused a short that changes the volume after a while when the speaker has been shaking for a period of time. You could try lowering the bass or volume to see if it makes a change in how long it takes to make the volume change.
Posted on Oct 22, 2008
Owner of companion 5 ... Like to sing on sing snap .... my mic wont work with it .. any solution ... thank you !
Posted on Nov 28, 2008
Hello, i have a dell Windows vista and my companion bose 5 wont work.. and ive tried it in another computer and it still wont work. what can be the problem?
Is there any system to which you can connect your BOSE *and* have it work?
If not, then check that the BOSE is getting electrical power into it.
Jul 19, 2011 | Bose Companion 5 Multimedia Speaker System...
Hi _ I got a new set of Bose Companion 5 - is working fine with my PC Windows Xp service pac II. suddenly the speakers go off wehile playing music & I have to restart the comp to hear music ?? Cant...
Try another set of speakers to eleiminate the BOSE speakers as being the issue (even cheap ones will do). If the problem does not re-occur, the issue is with the speakers.
If all the speaker jacks are plugged in correctly, I would consider returning this set, as it looks like the issue is within the circuitry of the Woofer
Jan 01, 2011 | Bose Companion 5 Multimedia Speaker System...
BOSE Companion 5 speakers connected to an Apple but no sound.
if you have a bose disk then you will need to run the install disk firsthope this helps if it does please rate this answer
May 12, 2010 | Computers & Internet
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
Do you have the USB cable plugged into your Mac?
Mar 20, 2010 | Computers & Internet
Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Dec 26, 2008 | Bose Companion III Computer Speakers
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Problems
email support@bose.com or contact a Bose Support Specialist in Germany; or call US support at 1-800-367-4008. Something very odd is happening here. You are using the same laptop, correct? If not, let me know, as there are some things to try. If Bose has a solution, I'd love to hear it.
Mar 19, 2008 | Bose Companion 3 Computer Speakers
1,524 people viewed this question
 Grubhead
Grubhead
