Question about Nokia e65 Cellular Phone
"No network" error
I am not able to receive or make calls on my nokia due to the error "no network". I had only just received this phone, it is not brand new my partner had upgraded so I took this phone. It was working earlier this afternoon, but not working now. Unsure what I had done, changed or pressed. Please help.
  • janzy Nov 03, 2008
    I just got it from ebay but my sim card in and i can do everything but call or msg on it
  • 586 Answers
Two possible ways to solve this kind of problem
1- Go to the settings---> phone settings--->network selection--->set it on auto selection mode.
2- Go to settings---> Restore factory settings it requires code of 5 digits that is 12345 for all Nokia sets.
Hopefully This will help to solve your problem.
Thanks
Posted on Oct 18, 2008
Nokia 2700 classic :problem subscribe packet data first-my connection is bsnl
This shows that you don't have the GPRS and MMS settings received on your phone.They are to be received from your Network Service Provider.Since you are using BSNL Network please do the following steps to receive the packet data settings on your phone.
Call 9400024365
OR
sms GPRS to 53733 to activate your GPRS service.Thanks for choosing Fixya.
Jun 21, 2011 | Nokia 5310 Cellular Phone
Im getting sim card registration failed error in nokia e63
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding Sim card problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone.
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
If the same Sim card doesn't not work on another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 24, 2011 | Nokia E63 Cell Phone
Cannot send or receive mms messages
It could be due to your network setting. Call your service provider.
Jan 16, 2011 | Nokia X3 Cell Phone
Cannot make a call msg comes up "connection error"
This is usually due to the phone being lock to a distant cell tower, if that is the case just shut the phone off and remove the battery wait about 2 minutes and replace the battery and restart the phone,if that doesn't fix the problem it may be an internal problem or a carrier problem.
Dec 01, 2010 | Nokia 6710 Navigator Cell Phone
My phone is not receiving messages
Hii
well according ur question, il take it as ur phone is working perfectly but ur unable to receive msgs, is that right?
Ok so there may be 2 probabilities either your inbox memory is full so try deleting some msgs inorder to free up the phone/sim memory
or
There might be Network issue, some time due to network congestion this does happens, try calling ur network operator customer care support.
Regards
Sep 07, 2009 | Nokia 6600
I am getting the below error when trying to make a video call on N95 Unable to make video call, not supported by other phone or network But the numbers I am calling are able to make and receive calls
Try performing a soft reset.
First backup all your data and contacts to your PC or memory card.
Then press the following keys *#7370#. The phone will ask if you want to restore all original settings. Select "yes". When the phone asks for a code type in 12345 and continue.
MAKE SURE YOU DO THAT BACKUP FIRST BECAUSE ALL YOUR DATA WILL BE WIPED.
Hope that helps.
May 17, 2009 | Nokia N95 Cellular Phone
Connection error
Connection error usually is because you set some restriction to make or receiv a call. However, this setting can also be done by the network provider.
And since you said you got no signal, means that your SIM card can not finish registering to the network, which normally means that your network provider is blocking your card. Same thing happen to pre-paid card which no longer in active period and already pass grace period.
I suggest you call the network provider, or come to their support center for solution.
Dec 14, 2008 | Nokia N70 Cellular Phone
Connectivity error
SOFT WARE NOKIA N95 CHAINS
Oct 31, 2008 | Nokia N95 Cellular Phone
Nokia N70
Go to Setting-Network-Operator Selection. Keep it Automatic
Go to Setting-Call-Send my caller ID. Keep it Set by network
& check your line in use. Keep it in Line 1
Jul 06, 2008 | Nokia N70 Cellular Phone
Nokia e65 Cellular Phone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
